Acer TravelMate P648 LA-D301P help bios dump
  • andrew25
    • Feb 2016
    • 222
    • Malawi
    i have the said acer which only light keyboard for 5sec then off, all volt are okay... i suspect has a bios issue, if someone help rebuiding my dump will apreciate or recreating a new file...
  • lapfix
    • Mar 2020
    • 2733
    • my workshop
    Re: Acer TravelMate P648 LA-D301P help bios dump
    Try
    • cinek228
      • May 2020
      • Poland
      Somone have EC Dump for this model?. Thanks
      • cinek228
        • May 2020
        • Poland
        My dump EC to verify.
        • paimz87
          • Feb 2022
          • 13
          • indonesia
          not working, any?
          • lint4u
            • Nov 2013
            • 115
            • lint4u
            Acer Travelmate LA-D301P
            Hello Sir
            Kindly pls help to repair my bios acer LA-D301P no display with fast fan spinning
            here i attach main bios and EC
            thanks for the help
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Re: Acer Travelmate LA-D301P
              Originally posted by lint4u
              Hello Sir
              thanks for the help
              Acer TravelMate P648-MG
              Model Number: TMP648-MG
              Part Number: NX.VC2SG.001
              Serial: NXVC2SG001737104793400
              Bios version: 1.21 (same as in your backup)
              DMI and Windows key transferred:
              Become a Badcaps supporter
              Thanks to all supporters.​
              • lint4u
                • Nov 2013
                • 115
                • lint4u
                Thank you Vesko356
                i will post the result later
                • lint4u
                  • Nov 2013
                  • 115
                  • lint4u
                  Hello again
                  Same issue no display with fast fan spinning
                  i thing some one already change the bios because serial number is different
                  here the correct label for S/N : NBVC21100D7376F8743400
                  is it problem different S/N for the blank display ?
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Hello again
                    This means in your case the problem is not bios related, because you can't find any better bios than this virgin file from the Acer support page for this model.
                    • lint4u
                      • Nov 2013
                      • 115
                      • lint4u
                      Thank you for your help and advice
                      Regards
                      • cekwork10
                        • Jul 2022
                        • 10
                        • philippines
                        Hello mates,
                        I have here Acer TravelMate P648 D4PB1 LA-F241P Rev.01, bios is lock after changing RTC Battery. I already try Online Bios password generator but no luck.
                        Here is my Dump File
                        Thank you in advance.
                        • spencertech
                          • Aug 2021
                          • 21
                          • south africa
                          i also need the bios bin
                        • almussafer
                          • Jun 2019
                          • 71
                          • Iraq
                          Try
                          thanks man it works 100%
                          • gabry120
                            • Nov 2019
                            • 38
                            • italia
                            Good morning, I have an Acer TravelMate P648-M-57TE. After updating the BIOS, it shut down and won't turn on again. Only the battery charging LED lights up, even when the battery isn't connected.
                            Thanks for your help.
                            • volinakis
                              volinakis commented
                              Editing a comment
                              Originally posted by gabry120
                              sn: NXVCLET039716002BF3400
                              snid: 71600070334
                              id motherbiard: NBVCL1100H715D83D43400 (if not this where i find it?)
                              try
                          • volinakis
                            • Jan 2021
                            • 2738
                            • N/A
                            post serial, SNID, motherboard id
                            • gabry120
                              • Nov 2019
                              • 38
                              • italia
                              snid: 71600070334
                                SMDFlea commented
                                Editing a comment
                                Thread merged.
                            • volinakis
                              • Jan 2021
                              • 2738
                              • N/A
                              snid: 71600070334
                              try
                              • gabry120
                                • Nov 2019
                                • 38
                                • italia
                                try
                                Thank You.
                                I tried, but it doesn't work, it does the same thing
                                • volinakis
                                  • Jan 2021
                                  • 2738
                                  • N/A
                                  Thank You.
                                  bios is extracted from update with your DMI, look for hardware problem (RAM, ssd, wifi, etc)
                                  • James194zt
                                    Acer Nitro 50-640E Corrupted BIOS Dump
                                    by James194zt
                                    My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                    All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                    04-28-2025, 03:29 PM
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                    Acer TravelMate TravelMate P6 TMP614-52 Netbook P6 Specification for Upgrade or Repair
                                    This specification for the Acer TravelMate TravelMate P6 TMP614-52 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate P6 TMP614-52 boardview and TravelMate P6 TMP614-52 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 05:20 AM
                                    Acer TravelMate TravelMate Spin B3 TMB311RN-31-C7XH Notebook Spin B3 Specification for Upgrade or Repair
                                    This specification for the Acer TravelMate TravelMate Spin B3 TMB311RN-31-C7XH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate Spin B3 TMB311RN-31-C7XH boardview and TravelMate Spin B3 TMB311RN-31-C7XH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
