Dell G5 15 5500 bios needed
G5 15 5500
SELEK MLK N18E
19753-1
FJT96SKA
SEVİCE TAG : C1RN0B3
please rebuild SERVİCE TAG AND clear ME
​Attached FilesComment
Attached Files↵
​https://www.badcaps.net/donateComment
Board Status: No Display - Fan spin at full speed
Work around: Replaced shorted KBC MEC-1515NB
- supplier said need to clean BIOS
Board Code: SELEK MLK N18E 19753-1 FJT96$LA
Service Tag: FP9V103
Please need help to repair and clean my BIOS
Where's your backup bios file ?↵
Dell G5 15 5500
Laptop stuck black screen turns on and off at max fan must remove battery to shut off cant access bios
Service tag:JYJG203
Dell G5 15 5500
The laptop does not display the logo when it turns on, it immediately goes into the system and it is not possible to enter the BIOS. Please clear ME. Thanks!
​ST: 43DHG63
MB:19753-1
Service Tag: 43DHG63​Attached Files↵
please can you provid a modified working bios and copy the service tag from the uploded old bios fileAttached FilesComment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Help me, please
my bios is corrupted and i use file bios on post #22
my service tag is 32M0763
and this is my original biosAttached FilesComment
Add service tag manually from bios setup save
next boot press Alt+F to exit manufacturing modeAttached FilesComment
Forgot to attach Splitted file
Now you may tryComment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by 417731Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
Model: Dell Vostro 3405
Tag:F0B1YF3
CPU:Ryzen 3500U
Thanks in advance-
by re1nholdHello Guys
I'm currently fixing two different Dell latitudes,
I need a E5550 BIOS - SERVICE TAG is: FSFB262
So far I flashed about 6 BIOS from this forum already,
none worked,
only fan spin ~3s, LCD black, keyboard LED on/off ok,
I tried manual extraction with scripts for ages so to speak. VM is untried yet.
This laptop is not burnt, it seems to just have a corrupted BIOS.
I extra baught ram. This has to work friends.
Do you generate it this way in Windows in CMD?:
Code:E5550A24.exe /writeromfile C:\bios.fd
- Loading...
