PCH has been replaced I need an unconfigured me region.
Dell G5 15 5500 bios needed
Hi, I have a dell g3 "15-3500-860?" that turns on but no display, can you clean the bios for me please, unfortunately I no longer have the label on the cover.
But the motherboard model is 19753-1, 10 ème génération. i7. nvidia
I tried post 9 and 133 but it doesn't work the laptop lights up, flashes then turns offAttached Files1 PhotoLast edited by madjid911; 04-27-2024, 07:17 AM.Comment
I tried post 9 and 133 but it doesn't work the laptop lights up, flashes then turns offAttached FilesComment
I have already looked, I have no shorts, the voltages are good, the battery charges well, the backlit keyboard lights up correctly, but no display, the shift key does not respond, I tried with an external screen, and I tried other rams, for me it probably comes from the bios but I tried many bios here nothing workedComment
if no image keep attach adapter and press pwr button to turn off and pres pwr button again to boot
power chocking also causes to no imageLast edited by qayyum786; 04-27-2024, 10:58 AM.Comment
that's what I did, but same result, I was lucky today to have another identical model laptop with HS processor, so I recovered the 3 eeproms but I didn't display, I no longer have the LEDs flashing but the shift key still does not respond, I suppose the bios of the other laptop were good so the problem does not come from there, so I swapped the two micro controller (KBC34 and STM32), but the result is still the same, yet I have all the voltages, I guess the processor or the graphics card must have a problem thenComment
Did you clean the ME firmware before trying the biosComment
Can you share those 3 eeproms ,they might help someone else https://www.badcaps.net/forum/troubl...15#post3217015
Did you clean the ME firmware before trying the biosAttached FilesComment
Hi friends
please i need Dell g5 15 5500 bios
MB:SELEK MLK N18E
19753-1
old bios sometimes work
service tag: 70R4563
please clean bios
i7 10th generation1 PhotoComment
Thẻ dịch vụ: 70R4563
Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Aarush653Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
Worked good before failed flash now won't power at all.
May have been a bad connection.
Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
32mb chip - 25Q256JVEN
Attach Dell Bios Update file v1.14 - original Dell update...-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
by bmxlovahHi,
My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...-
- Loading...
