HP Elitebook 830 G5 Admin Bios Unlock
  • shiyab
    • Sep 2023
    • 1592
    • india
    #81
    Originally posted by houcine4500
    hp elitebook 830 G5
    SN : 5CG9275T0H
    Produit: 2FZ83AV
    please remove PASSWORD​
    flash 16 mb ec file this unlock
    • Daniel López
      • Nov 2024
      • Spain
      #82
      Hi Team!
      I am not able to backup the bios, and it has an admin bios password, i am not able to reinstall Windows, enter bios...
      The model is HP EliteBook 830 G5 SN 5CG9132LB7
      is possible to reset the pass or remove it?
        • 21674
        Originally posted by Daniel López
        Hi Team!
        The only way to remove it is by backing up the contents of the bios chips using an SPI programmer,then posting your backups here for the pass removing, there`s currently no other way.
        • Razzpablo
          • Nov 2024
          • Romania
          #84
          Hei! My hp 830 G5 has a bios password
          ​​​​​. I cant enter it. Can I bypass or delete it? SN 5CG8392205.
          I'm a begginer 🫣
            SMDFlea commented
            Editing a comment
            Did you read the post above.....
        • hoaca388
          Badcaps
          • Jan 2022
          • 12268
          #85
          I'm a begginer 🫣
          Post the bios file (the one with the password) and serial number here.
          • ali0robot
            • Mar 2023
            • 78
            • N/A
            #86
            hi guys,
            i have programmed hp 830 g5 32mb bios with clean bios and after flashing password removed, but after some days costumer returned laptop and laptop was like a dead laptop, all voltage was ok but laptop could not turn on, I had reprogrammed ec and main bios with good bios bin but laptop could not turn on. just power led blinking white and amber continuously.
            could some one help me.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12268
              #87
              Originally posted by ali0robot
              hi guys,
              This is not related to the bios file, try replacing the bios chip.
              • ali0robot
                • Mar 2023
                • 78
                • N/A
                #88
                i have changed bios chip also.
                this thing happened for two costumer, i think it should related to bios bin.
                i have uploaded clean bios bin
                • Yassoun75
                  • Sep 2017
                  • 15
                  • France
                  #89
                  I need to unlock an EliteBook 830G5.
                  ProID: 2FZ83AV
                  SN: 5CG932148Z
                  Thank you.
                  • shiyab
                    • Sep 2023
                    • 1592
                    • india
                    #90
                    ProID: 2FZ83AV
                    SN: 5CG932148Z
                    Thank you.
                    post both file
                    • rex98
                      • Feb 2023
                      • 1289
                      • Mandaue CEBU, Philippines
                      #91
                      ProID: 2FZ83AV
                      SN: 5CG932148Z
                      Thank you.
                      1st boot press f10 apply factory defaults and restart, then flash back the original bios
                      • sarltap
                        • Apr 2016
                        • 96
                        • algerie
                        #92
                        830 G5 LOCK PLEASE UNLOCK
                        SN 5CG8433268 zz0.iirzqtb1kplzz
                        • shiyab
                          • Sep 2023
                          • 1592
                          • india
                          #93
                          post 16 mb
                          • sarltap
                            • Apr 2016
                            • 96
                            • algerie
                            #94
                            16M
                            • shiyab
                              • Sep 2023
                              • 1592
                              • india
                              #95
                              16M
                              hi try
                              • Oreoluwa Adeola
                                • Jan 2025
                                • Nigeria
                                #96
                                Please I need to delete the bios password for HP ELITEBOOK 830 G5
                                ORIGINAL BIOS ATTACHED​
                                SN# 5CG8416KND
                                • shiyab
                                  • Sep 2023
                                  • 1592
                                  • india
                                  #97
                                  SN# 5CG8416KND
                                  post both file
                                  • yassin1913
                                    • Feb 2015
                                    • 27
                                    • maroc
                                    #98
                                    can someone please help unlock pass
                                    serial:5CG9433YJ5
                                    • shiyab
                                      • Sep 2023
                                      • 1592
                                      • india
                                      #99
                                      serial:5CG9433YJ5
                                      hi try
                                      • yassin1913
                                        • Feb 2015
                                        • 27
                                        • maroc
                                        #100
                                        Thank U shiyab works perfect
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
                                        • intelg
                                          HP Elitedesk 800 G6 lost BIOS admin password
                                          by intelg
                                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                          Here is the hardware identification specs:
                                          HP EliteDesk 800 G6 Desktop Mini PC
                                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                                          Born on date: 07/26/2021
                                          SN MXL11841GN
                                          SKU 3X8V9UCHABA
                                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                          SYSTEM BOARD ID 8710
                                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                          11-03-2023, 02:05 AM
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
