HP Elitebook 830 G5 Admin Bios Unlock
  • peste
    • Dec 2016
    • 12842
    • ROMANIA
    #61
    Originally posted by mrmouse17
    I need to delete bios password. this is the original bios
    use RCUnlocker
    • mrmouse17
      • Oct 2021
      • 24
      • viet nam
      #62
      Originally posted by peste
      use RCUnlocker
      Thank you.I can't run 32mb files. it gives error
      • rex98
        • Feb 2023
        • 1278
        • Mandaue CEBU, Philippines
        #63
        Upload the EC chip and your Serial number.
        • binoyroy
          • Sep 2017
          • 51
          • bangladeah
          #64
          Uplode your 16Mb file in EC Side.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11772
            #65
            Serial number ?
            • KLINIK ELEKTRONIK
              • May 2019
              • 47
              • indonesia
              #66
              need unlock bios
              hp elitebook 830 G5
              SN : 5CG8418QY3
              MINBOARD :6050A2930901 MB A01 (A1)
              problem bios lock
              i have try bios this tread but no luck ( manufacture unlock mode , slow display )
              i have try hp unlocker still same lock bios.
              Below I uploaded the original bios.
              Thank you for your help
              • hoaca388
                Badcaps
                • Jan 2022
                • 11772
                #67
                Originally posted by KLINIK ELEKTRONIK
                need unlock bios
                hp elitebook 830 G5
                SN : 5CG8418QY3
                problem bios lock
                AAA
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #68
                  need unlock bios
                  hp elitebook 830 G5
                  SN : 5CG8418QY3
                  problem bios lock
                  Program both SPI modules and use verification, erase the each chip before programming.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                  • KLINIK ELEKTRONIK
                    • May 2019
                    • 47
                    • indonesia
                    #69
                    Originally posted by hoaca388
                    AAA
                    THANKS bios working
                    • KLINIK ELEKTRONIK
                      • May 2019
                      • 47
                      • indonesia
                      #70
                      thank VESKO365 now password clear
                      • gabsi
                        • Jul 2016
                        • 5
                        • France
                        #71
                        Please I need to delete the bios password for HP ELITEBOOK 830 G5
                        ORIGINAL BIOS ATTACHED
                        • rex98
                          • Feb 2023
                          • 1278
                          #72
                          serial number?
                          • gabsi
                            • Jul 2016
                            • 5
                            • France
                            #73
                            Originally posted by rex98
                            serial number?
                            SN#5CG940049W
                            • rex98
                              • Feb 2023
                              • 1278
                              #74
                              First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults.
                              search here bios config utility in forum in case you don' know.
                              Use BCU to fill these DMI INFO:
                              Serial Number: 5CG940049W
                              Product Number: 2FZ83AV
                              CT Number: PGSLU00WBCT0C2
                              Description: HP EliteBook 830 G5
                              build_id: 17WWCSDT601#SABF#DABF
                              Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPhKhkj4jh.DQ
                              MAC Address: 00-68-EB-3C-A0-19​
                              • gabsi
                                • Jul 2016
                                • 5
                                • France
                                #75
                                Thank you very much, it's perfect
                                • Kostyx87
                                  • Dec 2023
                                  • România
                                  #76
                                  I need to remove Bios Admin Pass for HP EliteBook 830 G5 - MB: 6050A2930901-MB-A01(A1) , i found two bios chip on the MB. One near the wifi card slot U365 and one near the KB connector U366. Wich one should i take down and flash?
                                  • peste
                                    • Dec 2016
                                    • 12842
                                    • ROMANIA
                                    #77
                                    on the 16MB one...
                                    • JAFATAGNA
                                      • Apr 2016
                                      • 59
                                      • MARRAKECH
                                      #78
                                      HP EliteBook 830 G5 Base Model Notebook PC
                                      Série: 5CG924BXQQ
                                      Produit: 2FZ82AV
                                      ​please remove computrace
                                      after connect pc to internet show lock screen
                                      • minhdigital
                                        • Nov 2022
                                        • 756
                                        • Vietnam
                                        #79
                                        Série: 5CG924BXQQ
                                        Produit: 2FZ82AV
                                        Send to you, First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults., Use BCU to fill these DMI INFO:​
                                        • houcine4500
                                          • Jun 2015
                                          • 59
                                          • morocco
                                          #80
                                          hp elitebook 830 G5
                                          SN : 5CG9275T0H
                                          Produit: 2FZ83AV
                                          please remove PASSWORD​
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • clrscr
                                            Need unlock bios hp elitebook 835 G11
                                            by clrscr
                                            please help me unlock bios password hp elitebook 835 G11
                                            S/N: 5CG50434RD
                                            thanks!...
                                            06-04-2025, 09:38 PM
