HP Elitebook 830 G5 Admin Bios Unlock
  • peste
    • Dec 2016
    • 13430
    • ROMANIA
    #61
    Originally posted by mrmouse17
    I need to delete bios password. this is the original bios
    use RCUnlocker
    • mrmouse17
      • Oct 2021
      • 30
      • viet nam
      #62
      Originally posted by peste
      use RCUnlocker
      Thank you.I can't run 32mb files. it gives error
      • rex98
        • Feb 2023
        • 1289
        • Mandaue CEBU, Philippines
        #63
        Upload the EC chip and your Serial number.
        • binoyroy
          • Sep 2017
          • 51
          • bangladeah
          #64
          Uplode your 16Mb file in EC Side.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12268
            #65
            Serial number ?
            • KLINIK ELEKTRONIK
              • May 2019
              • 49
              • indonesia
              #66
              need unlock bios
              hp elitebook 830 G5
              SN : 5CG8418QY3
              MINBOARD :6050A2930901 MB A01 (A1)
              problem bios lock
              i have try bios this tread but no luck ( manufacture unlock mode , slow display )
              i have try hp unlocker still same lock bios.
              Below I uploaded the original bios.
              Thank you for your help
              • hoaca388
                Badcaps
                • Jan 2022
                • 12268
                #67
                Originally posted by KLINIK ELEKTRONIK
                need unlock bios
                hp elitebook 830 G5
                SN : 5CG8418QY3
                problem bios lock
                AAA
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #68
                  need unlock bios
                  hp elitebook 830 G5
                  SN : 5CG8418QY3
                  problem bios lock
                  Program both SPI modules and use verification, erase the each chip before programming.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                  • KLINIK ELEKTRONIK
                    • May 2019
                    • 49
                    • indonesia
                    #69
                    Originally posted by hoaca388
                    AAA
                    THANKS bios working
                    • KLINIK ELEKTRONIK
                      • May 2019
                      • 49
                      • indonesia
                      #70
                      thank VESKO365 now password clear
                      • gabsi
                        • Jul 2016
                        • 5
                        • France
                        #71
                        Please I need to delete the bios password for HP ELITEBOOK 830 G5
                        ORIGINAL BIOS ATTACHED
                        • rex98
                          • Feb 2023
                          • 1289
                          #72
                          serial number?
                          • gabsi
                            • Jul 2016
                            • 5
                            • France
                            #73
                            Originally posted by rex98
                            serial number?
                            SN#5CG940049W
                            • rex98
                              • Feb 2023
                              • 1289
                              #74
                              First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults.
                              search here bios config utility in forum in case you don' know.
                              Use BCU to fill these DMI INFO:
                              Serial Number: 5CG940049W
                              Product Number: 2FZ83AV
                              CT Number: PGSLU00WBCT0C2
                              Description: HP EliteBook 830 G5
                              build_id: 17WWCSDT601#SABF#DABF
                              Feature Byte: 3X476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPhKhkj4jh.DQ
                              MAC Address: 00-68-EB-3C-A0-19​
                              • gabsi
                                • Jul 2016
                                • 5
                                • France
                                #75
                                Thank you very much, it's perfect
                                • Kostyx87
                                  • Dec 2023
                                  • România
                                  #76
                                  I need to remove Bios Admin Pass for HP EliteBook 830 G5 - MB: 6050A2930901-MB-A01(A1) , i found two bios chip on the MB. One near the wifi card slot U365 and one near the KB connector U366. Wich one should i take down and flash?
                                  • peste
                                    • Dec 2016
                                    • 13430
                                    • ROMANIA
                                    #77
                                    on the 16MB one...
                                    • JAFATAGNA
                                      • Apr 2016
                                      • 59
                                      • MARRAKECH
                                      #78
                                      HP EliteBook 830 G5 Base Model Notebook PC
                                      Série: 5CG924BXQQ
                                      Produit: 2FZ82AV
                                      ​please remove computrace
                                      after connect pc to internet show lock screen
                                      • minhdigital
                                        • Nov 2022
                                        • 764
                                        • Vietnam
                                        #79
                                        Série: 5CG924BXQQ
                                        Produit: 2FZ82AV
                                        Send to you, First boot press F10 reset bios to factory defaults & Restart, 2nd boot reset security settings to defaults., Use BCU to fill these DMI INFO:​
                                        • houcine4500
                                          • Jun 2015
                                          • 59
                                          • morocco
                                          #80
                                          hp elitebook 830 G5
                                          SN : 5CG9275T0H
                                          Produit: 2FZ83AV
                                          please remove PASSWORD​
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
                                          • intelg
                                            HP Elitedesk 800 G6 lost BIOS admin password
                                            by intelg
                                            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                            Here is the hardware identification specs:
                                            HP EliteDesk 800 G6 Desktop Mini PC
                                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                            BIOS ver S21 Ver. 02.05.01 01/05/2021
                                            Born on date: 07/26/2021
                                            SN MXL11841GN
                                            SKU 3X8V9UCHABA
                                            UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                            SYSTEM BOARD ID 8710
                                            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                            11-03-2023, 02:05 AM
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
