Asus ET2702I Bios Rev 1.3 BIOS request
  • mon2
    • Dec 2019
    • 14271
    Hi. Have an all-in-one Asus ET2702I that will not power on. The pushbutton is active low and can follow (using boardview file - no schematic available?) - the PB trace. See it go from HIGH to LOW with a button press. But the +12V mosfet does not turn on.
    MOSFET in question is @ PQ8906. If we GROUND the GATE on PQ8906, the +12V rail is passed through -> fan starts to spin.
    However, the ASUS MONITOR portion of this unit continues to state "NO VIDEO".
    Suspecting that the BIOS may be corrupt as the owner was hot swapping the external adapter to get the unit to turn on.
    Would someone have a dump of this BIOS or can we download an image from ASUS and it will be the same ?
    Believe the FLASH memory device for this logic board Rev 1.3 is @ MEU1.
    Thanks for any help / suggestions to repair this unit.
    • 21061
    Re: Asus ET2702I Bios Rev 1.3 BIOS request
    Post the bios backup, and a picture of any white/green stickers on the ram slot with a barcode on .
    • mon2
      • Dec 2019
      • 14271
      Thanks. Here you go.
      Given that the GATE of mosfet PQ8907 has no signal with the ON / OFF button being pressed - would it be logical to reflash the multiple devices onboard to repair this logic board ?
      Found all 3 of the flash devices.
      Thanks again.
        • 21061
        Just post the 16MB backup please
        • mon2
          • Dec 2019
          • 14271
          Thanks SMDFlea. Need to locate my programmer - actually have not yet used the one we purchased (CH341A based). Will do this on Monday. Many thanks.
            • 21061
            ok no problem. I recommend you try some different software with it, there`s NeoProgrammer ,AsProgrammer,Colibri and flashrom https://www.badcaps.net/forum/showpo...50&postcount=5
            • mon2
              • Dec 2019
              • 14271
              Hi @SMDFlea. Found my programmer
              Is it ok to use the BOTTOM side SMD pads to dump / program the orginal SOIC device(s) ?
                • 21061
                I don`t know as i don`t have the CH341A black PCB versio,mine are the older ones, green and blue,the pads are on the top but i always use adapters. Just check that the pins are going to the spi 25
                Voltage mod -https://www.chucknemeth.com/usb-devices/ch341a/3v-ch341a-mod
                • mon2
                  • Dec 2019
                  • 14271
                  Thanks. Finally was able to dump it. Had to modify this BLACK PCB to support +3v3 flash devices. As a default, it is 5V only and can fry the device. Google is my friend
                  Dump of the MACRONIX MX25L12873F
                  Welcome your feedback.
                    • 21061
                    Here you go
                    • jackcaper
                      • Oct 2023
                      • 8
                      Hi everybody and especially hello SMDFlea,
                      my ET2702I (Board Rev. 1.4, not like this 1.3, 16MB flash chip is a 25Q128FV) suffers from the same problem. Is it enough to replace the "PT1270691800" and "BCEE7B19AB44" with my respective identifiers in the cleaned 16MB file and flash it onto my system or is there more to edit?
                      Thanks for considering to help
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
