I need bios dell 5491 LA-F702p
  • tdelfy
    • Aug 2014
    • 113
    • usa
    thanks All
  • tdelfy
    • Aug 2014
    • 113
    • usa
    Re: I need bios dell 5491 LA-F702p
    yes i unlock and new sv tag
    • alpha pc
      • Mar 2023
      • 7
      • morocco
      i have this board not powering on cause of the bios so i need the demp files for it please !!
      ddp70 la-f702p rev 1.0 (a00)
      • b tech
        • Nov 2019
        • 9
        • pakistan
        I need bios dell 5491 LA-F702P
        thanks in advance
          • 22093
          thanks in advance
          https://www.badcaps.net/forum/troubl...sting?t=103570
          You MUST:
          • b tech
            • Nov 2019
            • 9
            • pakistan
            You MUST:
            dell latitude 5491
            DDP70 LA-F702P REV : 1.0(A00)
            S/T 9WD6NF2
            • kalilinux25
              • Mar 2018
              • 2093
              • ZAMBOANGA SIBUGAY
              dell latitude 5491
              S/T 9WD6NF2
              Do you have your dump file? backup file?
              • emaghanim
                • 134
                • egypt
                Dell Latitude 5491 bios error
                mb DDP70 LA-F702P REV1.0
                LED CODE 3.6
                SBIOS Flash Corruption - Flash corruption detected by SBIOS
                CAN YOU HELP ME REPAIR THIS BIOS
                THANKS
                  • 22093
                  LED CODE 3.6
                  THANKS
                  Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
                  Post the required service tag, read the rules https://www.badcaps.net/forum/troubl...before-posting
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    LED CODE 3.6
                    THANKS
                    what is the SERVICE TAG ?
                    • emaghanim
                      • 134
                      • egypt
                      sorry no srvtag on body
                      came dead
                      • emaghanim
                        • 134
                        • egypt
                        Thanks all
                        I have build one that works ok 100%
                        here it is for any one needs it
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • mikeybass
                          by mikeybass
                          04-23-2025, 04:30 PM
                        • capoplays
                          Help with BIOS update on Dell G15 5515 after chip replacement
                          by capoplays
                          Hey everyone,
                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                          When I check the BIOS using the F12 menu Flash...
                          10-24-2025, 06:53 AM
                        • Akhlz001
                          by Akhlz001
                          09-20-2025, 07:15 PM
                        • Sathsul
                          Dell Latitude 5431 issues with dumping bios
                          by Sathsul
                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                          10-28-2025, 07:49 AM
