Asus g752vsk vbios
  • myth77
    • Feb 2017
    • 380
    • Croatia
    Asus g752vsk vbios
    Hi, please i need gpu bios for model in title. It is g752vsk model not g752vs...Thx
  • peste
    • Dec 2016
    • 12658
    • ROMANIA
    Re: Asus g752vsk vbios
    post the bios backup
    • myth77
      • Feb 2017
      • 380
      • Croatia
      Attached!
        • 20705
        the attachment is 149.0 KB ,its not a good backup .
        • myth77
          • Feb 2017
          • 380
          • Croatia
          For vbios is small? Gpu bios? Hmmm i will check again...
          • myth77
            • Feb 2017
            • 380
            • Croatia
            its ok, when you extract it, it is around 1 mb, thats ok because it is gpu vbios W25Q80
              • 20705
              Oh sorry i didn`t read the first post properly, you want the vBios
              • myth77
                • Feb 2017
                • 380
                • Croatia
                yes
                • Francisco.s
                  • 686
                  • Spain
                  Here is the dump for g752vs vbios.
                  It have different content of your dump, but it is possible it helps you.
                  • grimacelord
                    by grimacelord
                    07-10-2025, 02:52 PM
                  • Kuroneox
                    Asus Vivobook 16 Model x1605v bios
                    by Kuroneox
                    Sorry for the inconvenience, I have a problem with an Asus, it turns on, it tries to start or the image freezes or it restarts, it doesn't let me put a system on it or put a disk with a system on it, it restarts them all, by chance I would have the Bios for this model
                    Asus Vivobook 16
                    Model x1605v
                    Model motherboard x1505va r2...
                    05-02-2024, 04:53 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • oragano
                    ASUS ex-b250-V7 motherboard bios corrupted - by me
                    by oragano
                    hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                    So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                    i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                    10-17-2024, 02:53 AM
                  • chudofermer
                    Asus Ally rc71l bios
                    by chudofermer
                    Hello!
                    Received Asus Ally rc71l with the wrong bios.
                    Have the original package and all serial numbers.
                    Can anyone help me understand what is wrong?
                    Condition:
                    Received with an original box with all serial numbers
                    Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                    Got the flash dump, nothing found on DMI section
                    No Windows key, just key ID on the box
                    What is done:
                    1. Flash the latest bios version with serial numbers...
                    03-05-2025, 05:42 AM
