Asus g752vsk vbios
  • myth77
    • Feb 2017
    • 380
    • Croatia
    Asus g752vsk vbios
    Hi, please i need gpu bios for model in title. It is g752vsk model not g752vs...Thx
  • peste
    • 12684
    • ROMANIA
    Re: Asus g752vsk vbios
    post the bios backup
    • myth77
      • Feb 2017
      • 380
      • Croatia
      Attached!
        • 20745
        the attachment is 149.0 KB ,its not a good backup .
        • myth77
          • Feb 2017
          • 380
          • Croatia
          For vbios is small? Gpu bios? Hmmm i will check again...
          • myth77
            • Feb 2017
            • 380
            • Croatia
            its ok, when you extract it, it is around 1 mb, thats ok because it is gpu vbios W25Q80
              • 20745
              Oh sorry i didn`t read the first post properly, you want the vBios
              • myth77
                • Feb 2017
                • 380
                • Croatia
                yes
                • Francisco.s
                  • 686
                  • Spain
                  Here is the dump for g752vs vbios.
                  It have different content of your dump, but it is possible it helps you.
                  • grimacelord
                    by grimacelord
                    07-10-2025, 02:52 PM
                  • Kuroneox
                    Asus Vivobook 16 Model x1605v bios
                    by Kuroneox
                    Sorry for the inconvenience, I have a problem with an Asus, it turns on, it tries to start or the image freezes or it restarts, it doesn't let me put a system on it or put a disk with a system on it, it restarts them all, by chance I would have the Bios for this model
                    Asus Vivobook 16
                    Model x1605v
                    Model motherboard x1505va r2...
                    05-02-2024, 04:53 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • oragano
                    ASUS ex-b250-V7 motherboard bios corrupted - by me
                    by oragano
                    hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                    So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                    i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                    10-17-2024, 02:53 AM
