HP bc402nw
  • reassor
    • Apr 2021
    • 176
    • Poland
    HP bc402nw
    MOBO : dag35nmb8c0 rev.C
    thx in advance
  • peste
    • 13450
    • ROMANIA
    Re: HP bc402nw
    thx in advance
    what problem do you have ??? post the backup of the bios ..
    • reassor
      • Apr 2021
      • 176
      • Poland
      Re: HP bc402nw
      Prooblem is when you press power screen flashes once then restarts 4 times (after bios CLR or flash and clr) and stays that way. Nothing on screen.
      I did find old bios (i mean i extracted it from oldest "bios_update.exe" on from Hp website (newer versions do not start the "extractor program". Compared $BID and found the right one. Its the same effect - so its not bios.
      Any ideas?
      • peste
        • 13450
        • ROMANIA
        Re: HP bc402nw
        Any ideas?
        if it is not bios move the discussion to the main forum, ask for help there ..
        • reassor
          • Apr 2021
          • 176
          • Poland
          Re: HP bc402nw
          can you check the bios ? maybe i fooked up?
          Did same version with sn transplant to same $BID
          there is no win key inside
          it contains me region (did not mess with that)
          Here is my (frankenstein file) - org dump is 2 posts up
          • reassor
            • Apr 2021
            • 176
            • Poland
            Re: HP bc402nw
            Wierd thing is i can even update it from usb O_o and i see it did it from log file on the "rescue usb" Still no display
            • peste
              • 13450
              • ROMANIA
              Re: HP bc402nw
              bios extracted from the HP site update, the laptop has three bios variants, yours is 084F8
              DMI 340000-3410FF
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • Cerberuska
                Mobo MSI B550-A PRO password popup
                by Cerberuska
                Hello guys,
                I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                BIOS I updated to last one.
                any suggestions?
                And same thing for two different 5600G, and yes, MoBo supposed to support it.
                Thank you...
                11-10-2024, 01:23 PM
              • mrsith
                Dell G3 17 3779 - no display after mobo replacement
                by mrsith
                Hi guys,
                I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                04-30-2023, 05:11 AM
              • Ibod
                Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                by Ibod
                HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                Not sure where to go from here ?
                Is the PSU at fault or is the mobo causing the problem
                Look forward to any help :-)
                If I plug the 24...
                02-08-2023, 11:00 AM
              • Felipe_Serra_83
                Dell Inspiron 14-5448 - fan turns off and mobo keeps running
                by Felipe_Serra_83
                Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
                So I got this Dell Inspiron to play with.
                No charger, so I connected to my bench PSU.
                The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
                ------What it did (and didn't do)------
                1) I turned it on and it powered on. Powered down in 2 seconds by itself.
                2) Removed RAM, changed slot. Same...
                04-04-2024, 12:39 PM
