NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
  • sassan
    • Apr 2014
    • 79
    • France
    #581
    Originally posted by SMDFlea
    Did you check the bios with ME Analyzer before flashing it ? ,i`ll bet the ME firmware was Initialised. The ME firmware should have been cleaned first , there are some guides if you want to have a go at cleaning it yourself https://www.badcaps.net/forum/troubl...22#post1622422
    If you`re going to use a bios from any intel machine check first if the ME is Initialised (Dirty) or Configured (Clean)
    For the endpoint error try the endpoint patch script at post #2 https://www.badcaps.net/forum/troubl...security-error , it will clear the NVRAM
    Thank you for your reply,You are right,the bin file is not clean,I tried this file from poste #2 which is clean,now the laptop works showing manufacturing mode ,the fan spins full speed, and late display.and no more security device Problem message.
    Any i dea please
      • 21692
      Any i dea please
      Enter the DMI info with HP Bios Config utility BCU and update the bios
        • 21692
        Originally posted by Jonjojonz
        someone help thankyou
        try
        • Jonjojonz
          • Dec 2022
          • 7
          • Indonesia
          #584
          try
          thankyo,, its end up same problem, first time show post error without ssd, when ssd plug in show like windows loading then bios update to 1.3.1 , many particular bios update can 100% done screen off n on to prosses update, but suddenly off in prosses update about 14%, i prees power button same problem at begining finishing bios update, my mobo have chip explode before. track broken i repaired n replace chip, what kind is chip this
          • Bault
            • Jul 2025
            • 4
            • India
            #585
            6050a2945601-mb-a01
            HP endpoint security problem anybody repair these bios
            ProdID 4DS10UC#ABA
            SN#56G93502TF
            this was burned on a regulator ic i cleared that after this is not turning on after we put it on sleep until i reconnect battery .
              • 21692
              Can`t see the marking code the IC picture is too blurred. Check if a schematic is available
                • 21692
                Originally posted by Bault
                6050a2945601-mb-a01
                ProdID 4DS10UC#ABA
                SN#56G93502TF
                Your main bios backup is only 65 bytes ,bad bad bad. Sometimes the endpoint error can be fixed using a patch script https://www.badcaps.net/forum/troubl...security-error
                • Jonjojonz
                  • Dec 2022
                  • 7
                  • Indonesia
                  #588
                  ic code sic534, base datasheet is for multi phase vrds for computing, graphic card n memory, is stiil work if this ic not present? during update bios is program stored in ssd?, btw thankyou bro
                  • Wutru
                    HP Elitebook 820 G4 BIOS repair assistance required
                    by Wutru
                    Hi guys,
                    If someone would be able to provide some expertise, I'd be very grateful.
                    BIOS Corruption - Cause
                    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                    09-06-2025, 10:32 AM
                  • STKR123
                    The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                    by STKR123
                    Greetings badcaps community,
                    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                    I learned that desoldering...
                    10-29-2024, 06:03 AM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • Guest
                    Elitebook 850 G5 BIOS bricked
                    by Guest
                    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                    I assume the BIOS update failed, so I searched for the BIOS chip.
                    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                    Can the corrupted...
                    03-24-2025, 01:21 AM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
