NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
Enter the DMI info with HP Bios Config utility BCU and update the biosComment
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
thankyo,, its end up same problem, first time show post error without ssd, when ssd plug in show like windows loading then bios update to 1.3.1 , many particular bios update can 100% done screen off n on to prosses update, but suddenly off in prosses update about 14%, i prees power button same problem at begining finishing bios update, my mobo have chip explode before. track broken i repaired n replace chip, what kind is chip thisAttached Filesif you find these attachements useful please consider making a small donation to the site
6050a2945601-mb-a01
HP endpoint security problem anybody repair these bios
ProdID 4DS10UC#ABA
SN#56G93502TF
this was burned on a regulator ic i cleared that after this is not turning on after we put it on sleep until i reconnect battery .Attached Filesif you find these attachements useful please consider making a small donation to the site
Can`t see the marking code the IC picture is too blurred. Check if a schematic is available
thankyo,, its end up same problem, first time show post error without ssd, when ssd plug in show like windows loading then bios update to 1.3.1 , many particular bios update can 100% done screen off n on to prosses update, but suddenly off in prosses update about 14%, i prees power button same problem at begining finishing bios update, my mobo have chip explode before. track broken i repaired n replace chip, what kind is chip thisComment
Your main bios backup is only 65 bytes ,bad bad bad. Sometimes the endpoint error can be fixed using a patch script https://www.badcaps.net/forum/troubl...security-errorComment
ic code sic534, base datasheet is for multi phase vrds for computing, graphic card n memory, is stiil work if this ic not present? during update bios is program stored in ssd?, btw thankyou broComment
i reflash bios again n i think it work, problem is ssd contain bios update in windows corrupt, i can enter windows instalation via fd, n i turning off, stoped cause dont have new ssd, but i plugin charger n taking current 2 amp n leaving about 1 hour(batterai connected), when i came back fun spinning full speed i cant turn off by pressing power,then i hold power button to shutdown but damn my laptop now dead just led, keybord blingking power plugin no taking curernt anymore, pressing pwr didnt react. why any sugestion?Comment
Post moved to 840 G5 topic. Please read https://www.badcaps.net/forum/troubl...before-posting and post the laptop serial number. Maybe you will find a working bios + EC_Bios in this thread topic ,try some.Comment
Hello every one. my laptop 840 g5 has no display caps lock blinks 5 times and after fast fan.
if any one can fix my bios. Thank you
serial:5cg8295cz3Attached Filesif you find these attachements useful please consider making a small donation to the site
6050a2945601-mb-a01
need to repair these bioses
problem is not turning on after sleep . i tried me clean but after it is turning off when we put to sleep and late display
ProdID 4DS10UC#ABA
SN#56G93502TFAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi Eveyone,I need big help,have this laptop,it turns on and just CapsLock blinking,noticed that the Main Bios is completely empty,I found other Dumps which are working but have 10sec late screen and on start ''HP Endpoint Security Controller Problem'',I will upload original and working dumps,if anyone can help,Thank you very much!
HP EliteBook 840 G5
ProdID 4WX66EC#ABD
SN# 5CG8376RB0
Motherboard: COMPUTRO-6050A2945601-MB-A01(A1)Attached Filesif you find these attachements useful please consider making a small donation to the site
try file fix endpointHi Eveyone,I need big help,have this laptop,it turns on and just CapsLock blinking,noticed that the Main Bios is completely empty,I found other Dumps which are working but have 10sec late screen and on start ''HP Endpoint Security Controller Problem'',I will upload original and working dumps,if anyone can help,Thank you very much!
HP EliteBook 840 G5
ProdID 4WX66EC#ABD
SN# 5CG8376RB0
hi please help me remove this security
SN: 5CG905327YAttached Filesif you find these attachements useful please consider making a small donation to the site
Thank you,but not working,Black screen with blinking CapsLock,I found the solution,Endpoint Security Controller Problem solved,dumps are Cleaned,just flash both files and enter Bios and write DMI informations,save,restart several times to lock MPM. Thank you Everyone!Attached Filesif you find these attachements useful please consider making a small donation to the site
Seri no 5CG8398HZ3
There was a security code, the leg broke off while disassembling the 256 one, I could not save the software inside, I bought MX25L25635FZ2I-10G instead of eprom and wrote the files by downloading them from the internet, but it does not trigger.
I would be happy if you could help. Thank you.
post S/N, full name and model ,motherboard model,.product number,,etc.Seri no 5CG8398HZ3
Every donation made will go towards server fees and maintenance costs.Comment
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
Channel: BIOS Requests ONLY!
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by macabookHello everyone,
07-24-2025, 02:17 PM -
by GuestHello,
I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
I assume the BIOS update failed, so I searched for the BIOS chip.
I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
Can the corrupted...-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Today, 04:04 PM - Loading...
