NEED BIOS FOR HP EliteBook 840 G5 6050a2945601-mb-a01
  • alontest
    • Aug 2018
    • 23
    • nowhere
    #521
    Originally posted by shiyab
    post both file 16mb ec
    Here you go, thank you
    • shiyab
      • Sep 2023
      • 1602
      • india
      #522
      hi try
      • alontest
        • Aug 2018
        • 23
        • nowhere
        #523
        hi try
        Hi thank you, is it enough just ec ? Asking as it requires full strip here and there to test
        • Zillions Tech
          • Jul 2022
          • 28
          • Nigeria
          #524
          I have Hp Elitebook 840 g5 it turns normally but shows an error message "END POINT SECURITY CONTROLLER PROBLEM"
          Please some should help me remove the end point error, i will attach the main and ec bin here
          S/N: 5CG038BBNM
          MODEL: Hp Elitebook 840 G5
          P/N: 6050A2945601-MB-A01
        • shiyab
          • Sep 2023
          • 1602
          • india
          #525
          S/N: 5CG038BBNM
          hi try
          • Zillions Tech
            • Jul 2022
            • 28
            • Nigeria
            #526
            hi try
            Not work, thank you
            comes up no display
            • AHSAN TARIQ
              • Jan 2025
              • 73
              • Pakistan
              #527
              Not work, thank you
              comes up no display
              YOUR PREVIOUS BIOS DISPLAY YET ORNOT
              • AHSAN TARIQ
                • Jan 2025
                • 73
                • Pakistan
                #528
                Not work, thank you
                comes up no display
                yet diplay then ty ths endpoint eror solve
                • han19977
                  • Sep 2021
                  • 15
                  • Pakistan
                  #529
                  hello guys, i have an issue with my 840 g5, its not detecting SSD, i did everything, i changed ssd, even i replaced ssd jack too, i checked all pins of ssd jack, and getting proper volts and signals, i think its bios issue,
                  also i tried to update bios from bios menu, its saying "Bitlocker drive encryption (BDE) is enabled on your system using TPM security", i think its bios issue, could anyone help me please
                  SN#5CG82302YN
                  • winix
                    • May 2023
                    • 5
                    • Nigeria
                    #530
                    Please I need help with my bios for Hp 840G5, I have programmed almost all bios file and EC file on this thread, none seems to work, I have been having different error light, some point bios corruption, and other bios and EC mismatch. Please help me with a working file please. Here is the backup of my ec and bios file
                    My laptop is
                    Hp Elitebook 840 G5
                    Core i5 8th generation
                    Model: HSN-113C-4
                    ProdID: 5JM99EC#ABH
                    SN: 5CG9062P70
                    • Stefan Steff
                      • Mar 2024
                      • 357
                      #531
                      My laptop is
                      Hp Elitebook 840 G5
                      Model: HSN-113C-4
                      ProdID: 5JM99EC#ABH
                      SN: 5CG9062P70
                      Your provided serial does not match any of the dumps provided...in fact the two dumps are from different laptops...anyways,
                      here you got two dumps (EC+BIOS) but you need to use BCU tool to enter factory data ... from your provided bios content is this:
                      Description: HP EliteBook 840 G5
                      Serial Number: 5CG8180LLR
                      Product Number: 2FA66AV
                      Board CT Number: PGWHT00WBAR2GG
                      BuildId(BID): 17WWCSAT601#SABH#DABH
                      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAgdhKhk.hy
                      MAC Address: B4-B6-86-8C-A2-6F
                      Good Luck!
                      • winix
                        • May 2023
                        • 5
                        • Nigeria
                        #532
                        Thank you so much for your swift response. I appreciate it so much.
                        So after flash the EC & Bios you provide, I get a steady white light with 11 amber then 6 amber blinking then restart.
                        Please kindly help me in anyway you can. Thank you
                        • Stefan Steff
                          • Mar 2024
                          • 357
                          #533
                          That dumps worked for me on several 840 G5 laptops.
                          First , you must check all components near the EC and BIOS chips to ensure you have not blow out any little resistor and second sometimes it takes a long time to boot for the first time after flashing both EC and BIOS and I mean even up to 5-10 minutes with several restarts.
                          Click image for larger version  Name:	EC.jpg Views:	0 Size:	501.5 KB ID:	3695808 Click image for larger version  Name:	BIOS.jpg Views:	0 Size:	203.6 KB ID:	3695809
                          • winix
                            • May 2023
                            • 5
                            • Nigeria
                            #534
                            Thank you sir, I will give it a try again sir
                            • iaf86
                              • Mar 2017
                              • 39
                              Hi, experts. I have an HP Elitebook 840 G5 with a locked bios password. Is there a method to remove the password without an EC chip? I can successfully remove passwords using patchers and RC unlockers, but I'd like to learn how to remove passwords using the main bios chip. I tried the HP unlocker, which created the unlock file but did not work. I attempted to delete the bios password manually using Hex editor and the Usercred method, but it did not work. I am posting the 32MB bios password locked.
                              Model: HP EliteBook 840 G5
                              S/N: 5CG85237RD
                              • peste
                                peste commented
                                Editing a comment
                                post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                            • peste
                              • 13562
                              • ROMANIA
                              #536
                              S/N: 5CG85237RD
                              post full name and model, motherboard model, product number,etc.
                              • albologna
                                • May 2022
                                • 31
                                • italy
                                #537
                                Hello
                                I have this Elitebook 840 G5 with no image, fan spins, total 0.250mHA consuption, little heat on PCH
                                With me analizer on main bios says "Detected CSE Extension 0x03 with wrong Partition Hash at FTPR > FTPR.man"
                                Serial 5CG9210D2C
                                ProductID 2FA66AV
                                Board 6050A2945601
                                Can somebody Help me rebuilt?
                                Uploaded Main bios with Ec chip bios
                                • hamza hamza
                                  • May 2022
                                  • 28
                                  • morocco
                                  #538
                                  can help me for clean me this bios
                                  HP EliteBook 840 G5
                                  NM: 6050A2945601 MB A01(A1)
                                  SN: 5CG8505KH2
                                  Thank you in advance
                                  • amitswami
                                    Delhi
                                    • Aug 2021
                                    • 57
                                    • rajasthan
                                    #539
                                    bios ic removed in my motherboard not backup bios file available any one please provide working clear me bios
                                    PROID :3RF15UT#ABA
                                    5CG82848PZ
                                    • RAMADHAN KASIMU
                                      • Sep 2023
                                      • 5
                                      • Tanzania
                                      #540
                                      Hi everyone, I hope you all fine
                                      I have hp EliteBook 840 g5 with error "High end point security problem"
                                      and not turn on with power button (turn on by reset BIOS always) any one help me to rebuild or clean this bios file below and any solution to make my laptop turn on with its power button, because I have tried to change EC chip, BIOS and LED sensor.
                                      Anyone to help me to rebuild bios file below
                                      product ID 5TG90PC#ABG
                                      SN# 5CG9302234
                                      Link https://drive.google.com/file/d/1m9G...usp=drive_link
                                      • Wutru
                                        HP Elitebook 820 G4 BIOS repair assistance required
                                        by Wutru
                                        Hi guys,
                                        If someone would be able to provide some expertise, I'd be very grateful.
                                        BIOS Corruption - Cause
                                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                        09-06-2025, 10:32 AM
                                      • STKR123
                                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                        by STKR123
                                        Greetings badcaps community,
                                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                        I learned that desoldering...
                                        10-29-2024, 06:03 AM
                                      • macabook
                                        by macabook
                                        🧩 Initial Issue
                                        07-24-2025, 02:17 PM
                                      • Guest
                                        Elitebook 850 G5 BIOS bricked
                                        by Guest
                                        I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                        I assume the BIOS update failed, so I searched for the BIOS chip.
                                        I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                        However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                        Can the corrupted...
                                        03-24-2025, 01:21 AM
                                        by Vesko356
                                        08-11-2023, 03:27 AM
