Asus X54UVK Rev 2.0 Bios dump
  • speggio91
    • Apr 2020
    • 83
    • Italy
    by suggestion of a member of this forum, I dumped the bios of this machine and attach it there. I request for a check of the image if its corrupted,
    thank you very much.
  • lapfix
    • Mar 2020
    • 2756
    • my workshop
    Re: Asus X54UVK Rev 2.0 Bios dump
    Try ..
    • speggio91
      • Apr 2020
      • 83
      • Italy
      Originally posted by lapfix
      Try ..
      Thanks. I can't get it to flash to any software, i am using the ch341A mini programmer with Neoprogrammer and when it has to verify the image it give a verification error.
      I think is the software that doesn't have in its database the bios chip i have (gigadevice 25B64CSIG).
      Is there any software that has that chip in the database?
      Or I can add it manually on neoprogrammer but I don't have the parameters.
      • peste
        • 13430
        • ROMANIA
        try this..
        https://www.badcaps.net/forum/showpo...6&postcount=10
        • speggio91
          • Apr 2020
          • 83
          • Italy
          Originally posted by peste
          That software seemed to have worked because it completed the flash process even if it couldn't verify the chip.
          But after soldering the chip back to the board there is no power, if i press the power button nothing happens.
          Before flashing the bios, the board turned on by itself just with the red led of the charger even if no battery was connected and when I pressed the power button the board powered on for a second then shut down.
          I believe the bios did not flashed correctly. I will try again or I'll buy a better programmer.
          Link to the repair board topic:
          https://www.badcaps.net/forum/showth...ghlight=x54uvk
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • ArkzG
            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
            by ArkzG
            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
            What I currently have available:
            - Model: FA506NF (2021)
            - BIOS chip: GD25LQ16 (16Mbit/2MB)
            - Tools: CH341A programmer ready to use
            Does anyone have either a clean 2MB .bin dump of this model,...
            09-26-2025, 09:34 PM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
