Bios dump Asus GL553VW rev 2.0
  • ammi
    • Mar 2017
    • 35
    • indonesia
    help me ...i need bios GL553 rev 2.0, this my bios whit no display
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Hi Can, anyone help with bios for this model Bios
    GL553VW rev 2.0
    Problem is no display, I was trying to clean bios because late screen, but after that no display at all with 2 files.
    I try some bios posted here in forum not working anyone.
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      Re: Bios dump Asus GL553VW rev 2.0
      Here is model based in motherboard sticker
        • 21692
        try this one .
        • digitalpc
          • Jun 2016
          • 305
          • .DLL
          Originally posted by SMDFlea
          try this one .
          Working now I have display, but laptop turn off trying to install windows, or botting windows
          I try different hdd
          • digitalpc
            • Jun 2016
            • 305
            • .DLL
            P.S
            In Safe Mode I can boot Windows
            • digitalpc
              • Jun 2016
              • 305
              • .DLL
              Sorry for 3post, I found thread with same problem like me exactly
              https://www.badcaps.net/forum/showth...gl553vw&page=3
              • questore
                • Dec 2015
                • 555
                • csongrád
                You probably have one/both failing CPU large capacitor or a failed Phase Mosfet. (usually the 2nd, middle one)
                You can confirm this by loading a command line linux from an usb in a "knoppix acpi=offsafe" mode, then: (this will allow only one thread on cpu to load)
                1. start a cpu load test. (it will be perform on 1 thread and 100% load fine)
                2. then start knoppix linux command line with normal mode and starting a cpu load test up to 8 times (8 CPU core thread).
                At one point you probably have an instant shutdown.
                (Usualy about 4 or 6)
                • snar
                  • Feb 2018
                  • 74
                  • philippines
                  Hi Everyone can someone help me fix this bios, the problem of this laptop is no power because of shorted vccgt mosfet i replace a new one and the laptop is turning on but it has no display. i will attach the original bios. thanks in advance.
                  laptop model: ASUS GL553VW-FY002T
                  board code: gl553vw ver 2.0
                  sn#:GANOCV16N437438
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • ArkzG
                    [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                    by ArkzG
                    Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                    What I currently have available:
                    - Model: FA506NF (2021)
                    - BIOS chip: GD25LQ16 (16Mbit/2MB)
                    - Tools: CH341A programmer ready to use
                    Does anyone have either a clean 2MB .bin dump of this model,...
                    09-26-2025, 09:34 PM
