help me ...i need bios GL553 rev 2.0, this my bios whit no display
Bios dump Asus GL553VW rev 2.0
Hi Can, anyone help with bios for this model Bios
GL553VW rev 2.0
Problem is no display, I was trying to clean bios because late screen, but after that no display at all with 2 files.
I try some bios posted here in forum not working anyone.Attached Files -
Re: Bios dump Asus GL553VW rev 2.0
try this one .Attached FilesComment
Sorry for 3post, I found thread with same problem like me exactly
https://www.badcaps.net/forum/showth...gl553vw&page=3Comment
You probably have one/both failing CPU large capacitor or a failed Phase Mosfet. (usually the 2nd, middle one)
You can confirm this by loading a command line linux from an usb in a "knoppix acpi=offsafe" mode, then: (this will allow only one thread on cpu to load)
1. start a cpu load test. (it will be perform on 1 thread and 100% load fine)
2. then start knoppix linux command line with normal mode and starting a cpu load test up to 8 times (8 CPU core thread).
At one point you probably have an instant shutdown.
(Usualy about 4 or 6)Comment
Hi Everyone can someone help me fix this bios, the problem of this laptop is no power because of shorted vccgt mosfet i replace a new one and the laptop is turning on but it has no display. i will attach the original bios. thanks in advance.
laptop model: ASUS GL553VW-FY002T
board code: gl553vw ver 2.0
sn#:GANOCV16N437438Attached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by kodoxneed original bios dump, original bios has flashed by other technician before me.
attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
unit info:
Model: Asus ExpertBook B1400CBA-0711A1235U
S/N: R6NXNZ006657238
CN: 7F6F
Mainboard Code: B1500CBA R2.1...-
Today, 12:20 PM -
- Loading...
