Lenovo IdeaPad 3 15ADA05
  • kodox
    • Jul 2017
    • 329
    • Indonesia
    #261
    Please fix the bios dump, it's from Lenovo IdeaPad 3. but the sticker for serial number is gone or any info about it
    just had the sticker & silkscreen on the motherboard
    • kodox
      • Jul 2017
      • 329
      • Indonesia
      #262
      anyone, please...?
      or just tell me where is DMI location based on my dump so i con extract and copy to a new bioa
      • peste
        peste commented
        Editing a comment
        you have over 300 posts try searching yourself...
    • peste
      • Dec 2016
      • 13701
      • ROMANIA
      #263
      anyone, please...?
      you have everything you need at post #204...
      https://www.badcaps.net/forum/troubl...da-bios/page11
      • kodox
        • Jul 2017
        • 329
        • Indonesia
        #264
        yes i can try any bios dump provided here, but i don't had enough info when i use tools (also provided here) to enter those DMI info.
        just hoping someone would extract those DMI info from the pictures i took, also lenovo support site doesn't provide any info i need
        • peste
          • Dec 2016
          • 13701
          • ROMANIA
          #265
          the bios from post # 204 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
          select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...​
          • kodox
            • Jul 2017
            • 329
            • Indonesia
            #266
            yes sir, i usualy used HxD program to move DMI info to a new bios with help UEFI Tool program, but on this bios i couldn't find it.
            though i couldn't fully understand when you said "select that interval mentioned in both bios", i manage to compare and locate DMI area using bios from post 252 & 253,
            sadly on my bios dump those area is empty
            • peste
              • Dec 2016
              • 13701
              • ROMANIA
              #267
              try..https://www.badcaps.net/forum/troubl...r-bootable-usb
              • kodox
                • Jul 2017
                • 329
                • Indonesia
                #268
                as per your suggestion, since i don't have any info about the unit i worked on (sn, uuid, mtm, etc...) i use info from un-repairable unit with same model and ofcourse used U1 tool too insert those info & worked.
                dead "ID" on repaired unit 😅. Thank you for the guide sir
                • Mister98
                  • Jun 2025
                  • 3
                  • Italia
                  #269
                  Hi, could someone help me with my corrupted BIOS file? For context, when I turn on my PC the power button LED lights up, the fan spins but the screen stays black. I tried some BIOS files from this thread, but to no avail.
                  Lenovo Ideapad3 15ADA05 Model Name 81W1 SN PF2TM0A0 MTM:81W100AYIX ; Motherboard: GS450&GS550&GS750 NM-C821 Rev 1.0
                  • peste
                    • Dec 2016
                    • 13701
                    • ROMANIA
                    #270
                    https://www.badcaps.net/forum/troubl...da-bios/page11​
                    • Mister98
                      • Jun 2025
                      • 3
                      • Italia
                      #271
                      Thanks for the reply!
                      I tried to extract the BIOS file from bios.cap and then followed the guide on how to copy the DMI information (as explained in the link that you provide, following post #1, the file attached to post #12 is not available "Invalid File Specified"). I flashed the .bin, turned on the PC but the screen remains black (no backlight), then I turned off the PC, pressed the Novo button for five seconds until I heard a "beep" from the motherboard, the PC turned on, the screen showed the Lenovo logo, then the boot manager and 2 seconds later the screen went black, I tried to turn on the PC again with the power button, then with the Novo button but it did nothing, just black screen, so I was curious if the Novo button did "something" to the BIOS file, so I made a dump of the IC and compared the .bin I flashed and the .bin from the dump with winmerge and found that the file in the IC was modified, I will attach the newbios.bin and the extracted.bin, now I have no idea what is going on
                      Thanks in advance!
                      • zetz
                        ZETZ
                        • Jan 2022
                        • 7
                        • colombia
                        #272
                        Good afternoon. Can anyone help me with the BIOS update for my Lenovo IdeaPad 3 GS450, GS550, and GS750 NM-C821 Rev 1.0 with IT8227E-128? I don't have the serial number because the sticker came off. Thank you very much.
                        • ridhomawardi
                          • Jun 2019
                          • 5
                          • Indonesia
                          #273
                          Help me Bios EC NM-C821 IT8227E-128
                            • 22035
                            Type the laptop serial number, full name and model, motherboard model, etc.
                            post the contents of the bios chip even if it is corrupted..
                            read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                            • Dexter898
                              • Jan 2021
                              • 30
                              • Croatia
                              #275
                              Please if someone have working BIOS, my original is in attach
                              Lenovo Ideapad 3 17ADA05
                              Model: 81W2
                              SN: PF2SDHT4
                              thx
                              • peste
                                peste commented
                                Editing a comment
                                post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                            • peste
                              • Dec 2016
                              • 13701
                              • ROMANIA
                              #276
                              Model: 81W2
                              SN: PF2SDHT4
                              thx
                              you have everything you need at post #11...
                              https://www.badcaps.net/forum/troubl...ed#post3661973
                              • Dexter898
                                • Jan 2021
                                • 30
                                • Croatia
                                #277
                                thx
                                • KameHouse
                                  • Feb 2023
                                  • 3
                                  • Chile
                                  #278
                                  working nice ty!
                                  • dazz khan
                                    • 5
                                    • UNITED KINGDOM
                                    #279
                                    BIOS FOR (Lenovo ideapad 3 ada05)
                                    100% WORKING
                                    EXTRACTED FOR PERFECTLY WORKING LAPTOP..
                                    • amitswami
                                      Delhi
                                      • Aug 2021
                                      • 61
                                      • rajasthan
                                      #280
                                      lenovo ideapad 3 15ada05
                                      model - 81w1
                                      sn: PF2LDFA5
                                      mtm 81W1003EIN
                                      mo- PF9XB1201005
                                      plz repair this bios
                                        Lenovo IdeaPad 3 15ADA05 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad 3 15ADA05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ADA05 boardview and 3 15ADA05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                        09-07-2024, 05:00 AM
                                      • jendkkd jeje
                                        Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                        by jendkkd jeje
                                        So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                        I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                        10-11-2024, 03:12 PM
                                      • joven016
                                        Lenovo Ideapad S145 need working bios HELP!!
                                        by joven016
                                        Problem is blinking power led only
                                        i don't know exactly if it's s145-15igm or s145-14igm
                                        have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                        Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                        Already tested some of posted bios here
                                        S145-14igm - success but invalid serial and not booting on OS
                                        S145-15igm - success with serial and some other info in bios but still not booting on OS
                                        already tried installing new windows but always booting on bios setup
                                        windows installer flash drive detected on...
                                        08-21-2025, 10:55 PM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
                                      • mximiliandz
                                        help bios lenovo ideapad s145-14iil type 81w6
                                        by mximiliandz
                                        Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                        06-20-2025, 06:50 AM
