HP 840 G6 BIOS - switch ON the MPM mode
  • Kazik
    • Oct 2016
    • 53
    Can you turn on the MPM (Manufacture Programming Mode) in this BIOS, please? Yes I need this BIOS in MPM mode.
    Eventually is there any tool to find MPM settings in BIOS (tool that can work with BIN files)?
    I know where that HEX is in 8MB BIOS but have no idea where to look for it in 32MB BIOS.
    Thank you.
  • alfanikos
    • Jul 2013
    • 39
    • Greece
    HP 840 G6 MPM (Manufacturing Programming Mode) turn on
    Can Someone indicate tthe procedure to Turn ON the Manufacturing Programing Mode) so as to am,end the DMI
    I have tried with the BCU urility by changing the star "**" from "Lock" position to "Unlock" position without any positive result.
    I understand that changes in the BIOS (by using the BCU) are only possible if the MPM is in Unlock condition
    If someone has different knowledge please post the experience gained.
    • vilmar27@hotmail.com
      • May 2023
      • 44
      • Brasil
      Please, could someone help me to Unlock the MPM to edit the DMI information of BIOS?
      HP Probook 640 G4
      Serial: BRJ9294026
      Part: 5WN41LP#AC4
      CT System: PHLRB0AGACC7RQ
      BuildId: 17WWC6CT601#SAC4#DAC4
      3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAcydUdpdqhk.AM
      Also someone know what HEX information in the BIN file I can edit to change the below information from Lock to Unlock?
      Unlock
      *Lock
      Tks,
      Vilmar
      • rex98
        • Feb 2023
        • 1297
        • Mandaue CEBU, Philippines
        HP Probook 640 G4
        Serial: BRJ9294026
        Part: 5WN41LP#AC4
        Unlock
        *Lock
        Tks,
        Vilmar
        here's your DMI info. Use BCU
        Serial Number: BRJ9294026
        Product Number: 5WN41LP#AC4
        CT Number: PHLRB0AGACC7RQ
        Description: HP ProBook 640 G4
        build_id: 17WWC6CT601#SAC4#DAC4
        Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAcydUdpdqhk.AM
        MAC Address: E4-E7-49-12-7B-C6​
          • May 2023
          • 44
          • Brasil
          Thanks a million rex98!
          • hypermk735
            • Jan 2024
            • 10
            How did you edit the BIN file to enable MPM? I am trying to do it myself.
            • gutkin
              SIR
              • Nov 2016
              • 22
              • argentina
              Hi, did you find out how to edit the MPM to UNLOCK?
              • alfanikos
                • Jul 2013
                • 39
                • Greece
                NO I have not done anything. I gave up . I have searched and stopped. The BIOS MPM remained as it was originally without any changes. If you find something just drop me a message (just form my information)
                  • 22279
                  Try this https://www.badcaps.net/forum/troubl...y-bios-patcher
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                    by SMDFlea
                    Bad...
                    09-02-2021, 04:40 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
                  • The_Memory_Guy
                    Dell T7820 stuck in Bios Recovery Mode
                    by The_Memory_Guy
                    HI,
                    I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                    What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                    All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                    https://www.dell.com/support/product...BUT090/drivers
                    Some...
                    07-07-2025, 06:52 AM
