GigaByte Aorus X7 DT V7 BIOS request
  • Rhadu23
    • Mar 2021
    • 74
    Me again
    Have a Gigabyte Aorus x7v7 in need of a working BIOS
    Here are details of it:
    S/N: GHN1C2211A0003
    Motherboard: GA-RX7Y7
    BIOS and EC attached.
    This is the version with 7th gen i7 and GTX 1080.
    Thank you in advance.
    • 21936
    Re: GigaByte Aorus X7V7 BIOS request
    The serial you posted is different to the one in the bios
    https://www.badcaps.net/forum/showth...ighlight=aorus Post #19 same bios .
    Try X7V710.B0D and X7V710.D0D.BIN .The D0D version is RAID.If neither of those boot then the problem is somewhere else.If it boots and you want to change the serial/win key you`ll need to use a hex editor.
    • Rhadu23
      • Mar 2021
      • 74
      That was the GTX1070 version.
      Will that make any difference or it might have a separate BIOS for GFX?
      • Rhadu23
        • Mar 2021
        • 74
        also the motherboards versions are different: GA-RX7X7 rev1.0 and this one is GA-RX7Y7 rev1.0.
        or are they the same.
        in looks, they look the same.
        nvidia chip different and cpu
          • 21936
          its the same bios from the support page .https://www.gigabyte.com/Laptop/X7-v...upport-dl-bios
          https://www.gigabyte.com/Search?kw=x7#Products-5-1
            • 21936
            Ok so the GA-RX7Y7 is for the X7 DT v7 .If you had put the DT in the first post and thread title.......
            • Rhadu23
              • Mar 2021
              • 74
              I am sorry Flea.
              I think I missed that...
              Really sory
                • 21936
                bios + win key from your backup
                • Rhadu23
                  • Mar 2021
                  • 74
                  Re: GigaByte Aorus X7 DT V7 BIOS request
                  looks like it is something else....
                  with the BIOS from above, the power button lights up then powers down after 10 sec, then if I press the power button again, the light stays on but nothing else.
                  north bridge gets warm
                  5v present
                  3.3v present
                  1v present
                  all looks like they should be, but... does not power on...
                  • Rhadu23
                    • Mar 2021
                    • 74
                    Any chance I can get some guidance?
                    If necessary, i will open a new thread in the correct location.
                      • 21936
                      The bios is good so yes open a new thread in the main forum - https://www.badcaps.net/forum/forumdisplay.php?f=23
                      • heni
                        • Apr 2021
                        • 6
                        • Ethiopia
                        Hey there. I have the same exact variant of the laptop you have (X7Y7 with a 1080). I updated my BIOS yesterday using the OEM app "drivers update" from gigabytes website. For some absurd reason it installed the X7X7 BIOS (1070 variant). Now the laptop isn't dead at least but installing GPU drivers is a lengthy process since the SUBSYS_ID of the GPU is changed to that of a 1070. I tried downloading and flashing the X7Y7 BIOS from their official website but that executable only sees the X7X7 BIOS that's currently running and it rejects to install. Is there anything can be done to fix this? Thanks in advance.
                          • 21936
                          You can try to make a backup of your current bios region by using FPT ,Flash Programming Tool .Run it from the command line .(not powershell). Post your backup in a zip or rar .
                          FPTw64.exe -bios -d biosreg.bin
                          • heni
                            • Apr 2021
                            • 6
                            • Ethiopia
                            Thanks for the quick reply.
                              • 21936
                              Try this bios,unzip from the folder and flash using the command:
                              FPTw64.exe -bios -f biosreg.bin
                              • heni
                                • Apr 2021
                                • 6
                                • Ethiopia
                                Error 368: Failed to disable write protection for the BIOS space.
                                FPT Operation Failed.
                                Is there a way bypass this write protection?
                                Edit: Also currently I don't have a programmer on hand so if you think it's too risky please do tell.
                                  • 21936
                                  Yes i forgot about that. Try this new bios,flash with AFU64 or try running flash.bat .AFU should bypass the protection, if it doesn`t you`ll have to buy a programmer.
                                  EDIT: Flash the X7V710.B0D version,i have added your win key to it .
                                  • heni
                                    • Apr 2021
                                    • 6
                                    • Ethiopia
                                    Alright I'll give it a shot once I get the programmer.
                                    Edit: It flashed successfully but it's still X7X7. Only thing that's changed is the bios version, It's older now.
                                      • 21936
                                      Did you reinstall the graphics driver
                                      • heni
                                        • Apr 2021
                                        • 6
                                        • Ethiopia
                                        Nope. I should have if it worked. I also checked the SUBSYS_ID in GPU-Z and it still shows 1070s value.
                                        • HFKoKoOo
                                          GIGABYTE AORUS 15P KD - BIOS Request
                                          by HFKoKoOo
                                          Hello guys im trying to find bios for laptop GIGABYTE AORUS 15P KD. I bought the laptop from marketplace and i thing that has broken bios because the laptops is turning on with black screen and not posting, also fans starting to spin when i heat little the laptop.
                                          Motherboard: GA-RX5LKD
                                          Thanks alot.
                                          05-07-2025, 12:12 PM
                                        • saisoni20
                                          Gigabyte Aorus RC45 - 6-77-NH50DD20-D02 BIOS Request
                                          by saisoni20
                                          Anyone can help me with virgin bios for Gigabyte Aorus RC45 - 6-77-NH50DD20-D02.
                                          Symptoms: Laptop is turning on. GPU is not detected in Device manager. Intel GPU is showing me in task manager used at 100%. Both fans starts spinning faster and unit shuts off.
                                          attached read bios.
                                          Thanks...
                                          12-04-2023, 07:53 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • sect-sin
                                          Gigabyte XT 6800 XT Aorus Master BIOS needed
                                          by sect-sin
                                          I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
                                          My last resort would really be flashing the...
                                          10-13-2023, 06:08 AM
