EPK50 LA-G073P Bios dump need
  • kalisko
    • May 2016
    • 45
    • Serbia
    Re: Hp 15-da epk50 la-g073p
    Originally posted by lapfix
    Try and give feedback
    Brother, you are a real emperor
    THANK YOU THANK YOU THANK YOU
    Bios turned on the laptop perfectly fine
    • el panke
      • May 2019
      • 78
      • argentina
      Re: HP Notebook 15-da0019la (EPK50 LA-G073P)
      Originally posted by SMDFlea
      Your bios BID is the same as the OP , BID084AA .The link to the bios is in the first post,run the exe to copy the 8MB 084AA.bin .Program the bios, then enter your DMI info using wndmifit/HP Bios config utility .
      thanx for ur help
      • kalisko
        • May 2016
        • 45
        • Serbia
        Has anyone solved this laptop when it flashes 5.3 ...
        I tried another bios flash ... nothing
        tried reboling CPU ... nothing ...
        Didn't the CPU die ???
        Some idea ????
        EPK50 LA-G073P Rev .: 1.0
        Processor: Intel Pentium Silver N5000, nVidia GeForce MKS110,
          • 20888
          did you flash the right bios,check the bios BID in your original backup
          • kalisko
            • May 2016
            • 45
            • Serbia
            Yes,
            The laptop turns on after the flash, but turns off after 10-15 seconds,
            It was like that several times (5 times), after that I couldn't turn it on
            what can happen to him?
            PS: when I take out the RAM it doesn't flash 3 times and it should ,,, be 5.3 again ... it doesn't register that the RAM has been taken out
              • 20888
              Originally posted by kalisko
              Yes,
              Post the original bios backup
              • kalisko
                • May 2016
                • 45
                • Serbia
                #27
                this is org, bios 1
                then went bios 2
                • kalisko
                  • May 2016
                  • 45
                  • Serbia
                  #28
                  I know and it can be anything ...
                  CPU, GPU, GPU frame, network card, music card, something about voltage, etc ....
                  he stopped strangely. after the bios flashes
                  HP support says:
                  5.3 (blink)
                  System board
                  The embedded controller times out waiting for the BIOS.
                  I don't know which controller times out ????
                  • dihcar84
                    • Aug 2012
                    • 193
                    • morocco
                    #29
                    try and give feedback
                    thank you soo much
                    • tsok
                      • Feb 2019
                      • 14
                      • philippines
                      #30
                      good day sir need help to clean my backup bios thank you much
                      • peste
                        • Dec 2016
                        • 12792
                        • ROMANIA
                        #31
                        post the full name and model of the laptop.
                        • Noreddin
                          • Jan 2020
                          • 73
                          • mostaganem
                          #32
                          thanks
                          • lapfix
                            • Mar 2020
                            • 2721
                            • my workshop
                            #33
                            Hp 15 la-G073P clean please
                            Hello friends , can anyone help me to clean this
                            Hp 15 la-G073P, thank you
                              • 20888
                              Re: Hp 15 la-G073P clean please
                              Open the bios with a hex editor,search for the DMI, it starts at 3C7000 ,the model number is 15-da0xxx ,enter that model at the HP support site https://support.hp.com/us-en/drivers...op-pc/20395828 ,download the bios update,if you can`t see any drivers listed change the OS to win 10 . Run the exe to extract all bios,or extract the first then second executables using 7-zip or winrar and decrypt the bios using hewprsa (google it) .Check your backup for the BID number ,copy the DMI from your backup to the virgin bios.
                              DMI 3C7000 - 3C8FFF
                              EDIT: Bios + EC posted in another thread - https://www.badcaps.net/forum/showthread.php?t=102610
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11733
                                #35
                                hello friends , can anyone help me to clean this
                                hp 15 la-g073p, thank you
                                • lapfix
                                  • Mar 2020
                                  • 2721
                                  • my workshop
                                  #36
                                  DMI 3C7000 - 3C8FFF
                                  Thank you my friend , i already do all this and dump the last one but still got the same issue : the caps lock blinks 5 times slow and then 3 times quickly...that's why i m asking to just clean the one i post , i can't clean it due to some error.
                                    • 20888
                                    What sort of error ,is it after you click Build
                                    EC attached
                                    • lapfix
                                      • Mar 2020
                                      • 2721
                                      • my workshop
                                      #38
                                      Re: EPK50 LA-G073P Bios dump need
                                      Thank you for the ec
                                      Error 7: [SMIP Controller] Invalid Manifest Extension Utility path. Manifest Extension Utility path set to: ''
                                      Error 6: [SMIP Controller] Failed to sign SMIP data.
                                      Error 37: [Ifwi Actions] Failed to build SMIP data.
                                      Error 19: [Ifwi Actions] Failed to prepare OEM SMIP data.
                                      Error 12: [Ifwi Actions] Failed to prepare one or more IFWI components.
                                      Error 15: Failed to build.
                                      Failed to build!
                                      • lapfix
                                        • Mar 2020
                                        • 2721
                                        • my workshop
                                        #39
                                        Originally posted by hoaca388
                                        thank you my friend , this is the same one that i already extracted, but same issue
                                          • 20888
                                          Failed to build!
                                          Platform Protection -> Platform Integrity ,it has an OEM public key hash .
                                          https://winraid.level1techs.com/t/gu...lization/31277
                                          D4. CSME 11 - 15 & CSTXE 3 - 4 .Follow step #7 carefully,you will need to install openssl to generate a key,and do a little hex editing.Its quite hard to do this until you get used to it.
                                          The Manifest Extension meu.exe is included in the System Tools folder
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            Today, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • MDSI
                                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                            by MDSI
                                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                            Details:
                                            Model : HP OMEN 17-an012nf
                                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                                            Serial Number (S/N) : 5CD7280D51
                                            BIOS chip : Winbond W25Q64VSIQ
                                            Programmer : EZP2023+
                                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                            I already...
                                            07-28-2025, 07:11 AM
                                          • grimacelord
                                            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                            by grimacelord
                                            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                            Motherboard model number: DA0PAMB46A1 REV: A
                                            Secondary motherboard model number: 0PAB
                                            SKU: 685K4UA
                                            Serial number is: 5CD3223BJP
                                            Recently reflashed this laptop with latest BIOS and once...
                                            05-07-2024, 08:06 AM
