HP ProBook 640 G4 BIOS request
  • O.Szilard
    • May 2019
    • 163
    • hungary
    #41
    Welcome! I would like help to check and repair the HP 640 G4 bios. The machine turns on, does not display a picture, the cooling fan rotates at high speed.
    Serial Number : 5CG8490D3L
    Product Number : 4NJ95EC
    Description : HP ProBook 640 G4 ​
    • tarek gouadma
      • Jun 2024
      • 44
      • Algeria
      #42
      try
      • O.Szilard
        • May 2019
        • 163
        • hungary
        #43
        Thank you very much, it works perfectly!!
        • O.Szilard
          • May 2019
          • 163
          • hungary
          #44
          After switching on, there will be a picture only after a minute, can it be fixed? Thanks!
        • tarek gouadma
          • Jun 2024
          • 44
          • Algeria
          #45
          try
          • O.Szilard
            • May 2019
            • 163
            • hungary
            #46
            Unfortunately, it hasn't changed. Possible motherboard error because there is an error message when switching on. but when Windows loads, there is no error in the device manager
            • tarek gouadma
              • Jun 2024
              • 44
              • Algeria
              #47
              Does the image still appear after a minute?
              • O.Szilard
                • May 2019
                • 163
                • hungary
                #48
                Yes after 1 minute, then an error message, enter and Windows loads. after that the machine works flawlessly.
                • tarek gouadma
                  • Jun 2024
                  • 44
                  • Algeria
                  #49
                  We will prepare it as it came out of the factory
                  • Stefan Steff
                    • Mar 2024
                    • 345
                    #50
                    Do you know how to enter DMI information to the BIOS ?
                    This info...
                    Description: HP ProBook 640 G4
                    Serial Number: 5CG913468M
                    Product Number: 3WW24AV
                    Board CT Number: PGSUL00WBC10GT
                    BuildId(BID): 17WWC6CT601#SAK8#DAK8
                    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAhk.F4
                    MAC Address: 7C-D3-0A-70-5C-74
                    • O.Szilard
                      • May 2019
                      • 163
                      • hungary
                      #51
                      Professional work! I am grateful! You helped me a lot, thank you very much! And the owner of the machine also thanks
                      • tarek gouadma
                        • Jun 2024
                        • 44
                        • Algeria
                        #52
                        enjoy your time
                        • O.Szilard
                          • May 2019
                          • 163
                          • hungary
                          #53
                          This info...
                          Yes! It worked, thank you!
                          • Stefan Steff
                            • Mar 2024
                            • 345
                            #54
                            You're welcome!
                            • Md Jibrail
                              • Mar 2023
                              • 21
                              • Saharsa
                              #55
                              Originally posted by Spider1211
                              Re: HP ProBook 640 G4 BIOS request
                              Try and report back.
                              As SMDFlea mentioned, use your original BIOS. Use your original 16Mb dump and the attached 32Mb cleanME.
                              Thanks tested okkkkkkkkk
                              • Ismael Shah
                                • Jul 2021
                                • 8
                                • india
                                #56
                                LATE DISPLAY PLEASE SOLVE
                                SR N. 2TK929077V
                                CPU. SR3LA (Intel Core i5-8250U)
                                BOARD ID 6050A2930101-MB-A01
                                • amine23000
                                  • Nov 2022
                                  • 6
                                  • Algérie
                                  #57
                                  my latop run but not display .
                                  need the correctif dunp
                                  serial number : 5CG917O6QW
                                  • shiyab
                                    • Sep 2023
                                    • 1592
                                    • india
                                    #58
                                    HI try
                                    • Aadi Mirza
                                      Aadi Mirza
                                      • Oct 2023
                                      • 17
                                      • Oman
                                      #59
                                      HP BIOS6050A2930101-MB-A01 OK CLEAR 100%
                                      • almussafer
                                        • Jun 2019
                                        • 82
                                        • Iraq
                                        #60
                                        Thanks, man its works 100%
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Soumana Sanou
                                          “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                          by Soumana Sanou
                                          Hello,😇😇😇
                                          I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                          🔧 Model: HP ProBook 11 G2
                                          📦 Serial Number: 8CG72478MY
                                          🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                          🔒 BIOS Status: Locked with password
                                          The laptop is no longer under warranty and HP refused to help me.
                                          I’m looking for a custom SMC.bin file.
                                          I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                          Thanks a lot for your help!🙏🙏🙏...
                                          06-17-2025, 04:04 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
