HP ProBook 640 G4 BIOS request
  • Rhadu23
    • Mar 2021
    • 74
    Can I please have a clean, fresh BIOS for HP ProBook 640 G4?
    SN: 5CG9260GK2
    It is the version with 8th gen i5.
    Symptoms: powers on, no display, fan at full blast.
    Attached is the old BIOS and a new one found on the internet.
    • 22279
    Re: HP ProBook 640 G4 BIOS request
    Try cleaning the ME firmware first in your original bios backup. If its only that thats coruupt then its an easy fix ,plus you won`t lose any DMI info.If you use a bios from another machine then you`ll have to change your DMI using the hp DMI tools. Also there`s no point posting a bios "found on the internet" unless its a known working one with clean ME FW, and the correct bios version.This model has 2 different bios versions, Q83 and Q77 ,you should open your bios with a hex editor and find out which one you have by using the hex editors text search function .
    ME Cleaning guide - https://www.badcaps.net/forum/showthread.php?t=88533
    HxD Hex editor - https://mh-nexus.de/en/hxd/
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Try and report back.
      As SMDFlea mentioned, use your original BIOS. Use your original 16Mb dump and the attached 32Mb cleanME.
      • Rhadu23
        • Mar 2021
        • 74
        Thank you both for the replies.
        I will try it on Monday.
        • Rhadu23
          • Mar 2021
          • 74
          I have followed your advice and used the original BIOS and now it works.
          Only one error: The MUD from the embeded controller is different than the MUD in the BIOS.
          That is what it says upon powering up.
            • 22279
            Post your 32MB backup.
            • Rhadu23
              • Mar 2021
              • 74
              Is the one from Spider1211's post
                • 22279
                I meant your 16MB backup .
                • Rhadu23
                  • Mar 2021
                  • 74
                  You can find it in my first post: the "old.zip" file
                    • 22279
                    Your 32MB backup was corrupt. Try this bios .If there`s any more error messages try and update the bios with the one at the support site .
                    • Rhadu23
                      • Mar 2021
                      • 74
                      just installed Windows and sone all updates, and after 2nd restart, the BIOS was automatically updated to version: 01.10.00
                      Also, it updated the Intel Management Engine Firmware.
                      Updated CCG5 aswell.
                      PEIA Region also updated.
                      USB-C Controller Firmware updated.
                      All of the above happened after Windows updates.
                      After all of that, it bluescreened with kbdclass.sys error
                      Then bluescreened again with some kernel error.
                      The initial error is now gone and the laptop has now booted to Windows with USB and trackpad not working....
                        • 22279
                        Flash the latest bios from HP,don`t let microsoft do it . https://ftp.hp.com/pub/softpaq/sp112...0/sp112372.exe .Try the drivers at HP support listed under "Driver-Keyboard, Mouse and Input Devices"
                        https://support.hp.com/gb-en/drivers...ok-pc/18602168
                        • Rhadu23
                          • Mar 2021
                          • 74
                          I have tried to update the bios with the official one and now... back from where we started
                          Looks like i have to do it the hard way
                          • paimz87
                            • Feb 2022
                            • 13
                            • indonesia
                            HP ProBook 640 G4 locked bios,tried with unlocker but pass remains,any help?Thanks...
                            • mrwab
                              Banned
                              • Jan 2014
                              • 83
                              • morocco
                              try
                              • paimz87
                                • Feb 2022
                                • 13
                                • indonesia
                                Thank You bro.. it's working
                                • mrwab
                                  Banned
                                  • Jan 2014
                                  • 83
                                  • morocco
                                  Welcome, put the board code so that others can benefit from it
                                  • Usman1
                                    • Oct 2020
                                    • 8
                                    • UAE
                                    hp 640 g4 remove pasword anyone help me
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      Originally posted by piernov
                                      — You are requesting help
                                      If you do not abide by the following rules, your post will be deleted.
                                      You MUST NOT:
                                      • Post a request in multiple threads
                                      • Post a request multiple times
                                      • Kesavan
                                        • Aug 2016
                                        • 205
                                        • India
                                        Hp 640 g4 laptop received for late display issue, so tried for csme clean. After that board not power on. Anyone can help me?
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Soumana Sanou
                                          “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                          by Soumana Sanou
                                          Hello,😇😇😇
                                          I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                          🔧 Model: HP ProBook 11 G2
                                          📦 Serial Number: 8CG72478MY
                                          🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                          🔒 BIOS Status: Locked with password
                                          The laptop is no longer under warranty and HP refused to help me.
                                          I’m looking for a custom SMC.bin file.
                                          I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                          Thanks a lot for your help!🙏🙏🙏...
                                          06-17-2025, 04:04 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
