HP ProBook 640 G4 BIOS request
    Welcome! I would like help to check and repair the HP 640 G4 bios. The machine turns on, does not display a picture, the cooling fan rotates at high speed.
    Serial Number : 5CG8490D3L
    Product Number : 4NJ95EC
    Description : HP ProBook 640 G4
      try
        Thank you very much, it works perfectly!!
          After switching on, there will be a picture only after a minute, can it be fixed? Thanks!
          try
            Unfortunately, it hasn't changed. Possible motherboard error because there is an error message when switching on. but when Windows loads, there is no error in the device manager
              Does the image still appear after a minute?
                Yes after 1 minute, then an error message, enter and Windows loads. after that the machine works flawlessly.
                  We will prepare it as it came out of the factory
                    Do you know how to enter DMI information to the BIOS ?
                    This info...
                    Description: HP ProBook 640 G4
                    Serial Number: 5CG913468M
                    Product Number: 3WW24AV
                    Board CT Number: PGSUL00WBC10GT
                    BuildId(BID): 17WWC6CT601#SAK8#DAK8
                    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAhk.F4
                    MAC Address: 7C-D3-0A-70-5C-74
                      Professional work! I am grateful! You helped me a lot, thank you very much! And the owner of the machine also thanks
                        enjoy your time
                          This info...
                          Yes! It worked, thank you!
                            You're welcome!
                              Originally posted by Spider1211 View Post
                              Re: HP ProBook 640 G4 BIOS request
                              Try and report back.
                              As SMDFlea mentioned, use your original BIOS. Use your original 16Mb dump and the attached 32Mb cleanME.
                              Thanks tested okkkkkkkkk
                                LATE DISPLAY PLEASE SOLVE
                                SR N. 2TK929077V
                                CPU. SR3LA (Intel Core i5-8250U)
                                BOARD ID 6050A2930101-MB-A01
                                  my latop run but not display .
                                  need the correctif dunp
                                  serial number : 5CG917O6QW
                                    HI try
                                      HP BIOS6050A2930101-MB-A01 OK CLEAR 100%
                                        Thanks, man its works 100%
