HP 14-ce0064st IO controller IT8987E 1832-BXA program
  • SuperAman
    • Dec 2018
    • 121
    I need HP 14-ce0064st IO controller IT8987E 1832-BXA program. Laptop powers on, no display and blinking caps. All power rails are present. I need to program IO and need file.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: HP 14-ce0064st IO controller IT8987E 1832-BXA program
    post the main bios and EC bios ..
    • SuperAman
      • Dec 2018
      • 121
      You need me to upload the dump file?
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        I need the original main bios and EC bios of the laptop ... read the bios and EC chip and post the content ...I/O bios..
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
          07-23-2023, 07:39 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • Mita99
          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
          by Mita99
          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
          04-27-2025, 07:20 PM
        • sikocan
          Lenovo X1 Carbon 9th Gen Black Screen
          by sikocan
          I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
          SN: PF3G1REP
          MODEL: 20KW-00J1AU
          PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
          Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
          06-24-2025, 09:01 PM
