HP EliteBook 845 G7 BIOS Pass
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #101
    Re: HP EliteBook 845 G7 BIOS Pass
    Originally posted by Dan20701
    Thank you very much for being so quick.
    Thanks.
    You're welcome.
    Please consider donation in support of the "Bios Request" section of the forum.
    Become a Badcaps supporter
    Thanks to all supporters.
    • drewrox2009
      • May 2016
      • 14
      Is there a definitive method for clearing these passwords? I did try clearing the nvramactive area on the 32mb dump and the bios log persists. If i understood the previous post, this is the ec chip and should only be necessary to clear on this chip (u367)
      Is it situational?
      • yuan22231
        • May 2022
        • 17
        • Philippines
        #103
        help me to remove password bios hp 845 g7
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #104
          • yuan22231
            • May 2022
            • 17
            • Philippines
            #105
            thanks bro its working ...
            • Fayted
              • May 2023
              Could you please help me remove the BIOS password on my HP Elitebook 845 G7. I tried modifying the files myself, but it didnt seem to work. Here are the original BIN files for both the bottom and top chips. If you need any additional information or files please let me know. Thank you for your time.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #107
                • kasuraga
                  • Aug 2023
                  Re: HP EliteBook 845 G7 bios cleared request
                  Originally posted by dariuxzy
                  hey, i'm looking for clean bios and ec dumps, i tried to flash both with files taken in a thread but the laptop won't start and caps lock blinking 7 times (I guess because they are not clean)
                  I don't have the original backup up because the original ec i broke it before i even read it..., so i buy another one!
                  Thank you so much, I'm losing my mind for this laptop!
                  Bios: MX25L25673
                  EC: W25Q256JVEN
                  Motherboard: LINDEN-6050A3147201-MB-A01(A1)
                  Ugh I just did the same stupid effing mistake. Ground pin busted off on the EC. can't find any remnants of the pin to try and attempt reviving the chip. I'm under the impression that I might be able to flash the bios and ec once I replace the ec to get it running again? How screwed am I here?
                  And here I thought I would have a nice afternoon reviving this system.
                  • kasuraga
                    • Aug 2023
                    Originally posted by kangajoe
                    I have found that much of the information in many forums around this problem have been missing a lot of vital information.
                    After my own research and experience I have documented exactly what worked for me.
                    I hope that others may find this helpful.
                    Ok, so I was able to salvage another system to try this unlock. I followed all the steps, and bam, it DID remove the password, but now I have the endpoint security controller error. I'm assuming that's why people here request both bios to do the unlock? what should I modify in my main bios to remove this error?
                    I've attached a dump of both top and bottom chips if anyone can unlock them for me. I tried comparing to other bios and even though I find the area's commonly modified it doesn't seem to be what I need to modify on mine? (I have the unedited bottom bin in my zip)
                    • alfredodinolfo
                      • 128
                      • N/A
                      #110
                      thank you
                      Last edited by alfredodinolfo; 09-04-2023, 11:39 AM. Reason: Bios removed, thread hijack.
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #111
                        Originally posted by alfredodinolfo
                        Probook 635 G7
                        MB:LINDEN-6050A3147201-MB-A01
                        no video.
                        I programmed both spi (U366_U365 and U367), now video com'in but show error end-point and ask password.
                        attached original dump.
                        Thank your for help.
                        Off topic, this thread is for HP EliteBook 845 G7 only!
                        Read the rules, next time don't hijack threads or you will receive an infraction
                        • alfredodinolfo
                          • 128
                          • N/A
                          #112
                          Sorry i mystake because is same mb code. Remove it if off-topic.
                            • 20349
                            If a thread title has only a laptop model number then only requests for that same model should be made.If a thread title has a motherboard model number only,then any laptop model number can be posted in that thread if the motherboard (including revision etc) is the same.
                            • jatoi
                              • Jan 2015
                              • 82
                              • pakistan
                              #114
                              please removed bios password
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11250
                                • Viet Nam
                                #115
                                aaaaaaaa
                                • jatoi
                                  • Jan 2015
                                  • 82
                                  • pakistan
                                  #116
                                  thanks
                                  • rex98
                                    • Feb 2023
                                    • 1240
                                    • Mandaue CEBU, Philippines
                                    #117
                                    Originally posted by peste
                                    try this..modify only this bios ... the other one stays the same ..
                                    thanks for this it removed my absolute lock.
                                    I unlocked by myself the bios password in EC and i used this as main and it works.
                                    • erniel01
                                      • Oct 2023
                                      • Philippines
                                      #118
                                      please help me to unlock
                                      probook 845 g7
                                      advance thanks
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11250
                                        • Viet Nam
                                        #119
                                        probook 845 g7
                                        advance thanks
                                        Serial number ?
                                        • erniel01
                                          • Oct 2023
                                          • Philippines
                                          #120
                                          Originally posted by hoaca388
                                          Serial number ?
                                          here sir
                                          SN# 5CG1161239
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • zlr8r
                                            looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                            by zlr8r
                                            looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                            cheers
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                            Attached;
                                            1. My saved bios using a programmer
                                            2. Dells Bios updater .exe (v1.16)
                                            3. Dells Bios recovery file
                                            4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                            5. Image of ME...
                                            12-18-2023, 03:08 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • what_1282105
                                            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                            by what_1282105
                                            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                            02-14-2025, 07:27 PM
                                          • Bloodhoundje
                                            by Bloodhoundje
                                            03-16-2024, 03:12 PM
