SMDFlea I did everything you mentioned , Now it trigger bitlocker and the owner check every accounts and he didn`t find any devices registered in his accounts. Can I copy some blocks for bitlocker too?
Need bios lenovo yoga C930-13IKB
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by maesonHi dear Badcaps-Community,
Somehow an auto update, which I triggered before I left my laptop unattended, bricked my BIOS.
I was able to extract the 2MB BIOS and 16MB BIOS which I will attend. (CH341B black with NeoProgrammer 2.2.0.10)
The Device is a Lenovo Yoga L13 Gen3 and I was able to identify the following specifications:
Lenovo Yoga L13 Gen 3 AMD:
Lenovo Modell: Type 21BB
Artikelnr.21BB006GGE
Seriennummer: PW0A6207
AMD Ryzen™ 5 PRO 5675U
Memory 16 GB DDR4-3200MHz
SSD: 512 GB SSD, M.2 2242, PCIe Gen4, TLC,...-
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by AYsysHello dear forum members,
I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
Nothing was flashed here — the BIOS was only backed up.
I created the backup using a CH341A Black programmer and NeoProgrammer....-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
