Need bios lenovo yoga C930-13IKB
Every donation made will go towards server fees and maintenance costs. -
Re: Need bios lenovo yoga C930-13IKB
Apologies -- incredibly new here. I bought a clip, I have a Pi and I'm about to (hopefully) dump my password protected BIOS. I found a "Winbond 25080dvsig" chip -- which, I think is the BIOS chip. Does this sound correct?
Also -- when I'm using the clip/Pi to take a dump of the BIOS, do I need to remove the battery from the laptop first? (Old plastic makes me nervous)Comment
Lenovo Yoga c930-13ikb
Board Name : NM-B741 EYG70 rev 1.1
SN :PF1MGYJS
Problem : Power Button Led blinking and no displayAttached FilesComment
Re: Lenovo Yoga c930-13ikb
Yoga C930-13IKB Glass Laptop (Lenovo) - Type 81EQ↵
https://www.badcaps.net/donateComment
Hi Need BIOS please :-)
Lenovo Yoga C930-13IKB
Board Name : EYG70 rev 1.1 NM-B741
SN :PF1GMYRV
Problem : Power Button Led blinking and power off after few secondsAttached FilesComment
Yoga C930-13IKB Laptop (Lenovo) - Type 81C4
Tried the BIOS provided but no change, board is having power for few seconds but not posting.
i just saw this board has one more bios chip.
from the sizes it seems different.
can someone please advise, which one is the main and what is the data stored on the second chip?Comment
Hi, I have a C930-13IKB That charges and has caps lock, but no image on internal or external screen. I think the BIOS is corrupted.
Model: YOGA C930
SN:PF1Q4AN4
Motherboard Model: NM-B741
MTM:81C4000EUSAttached FilesComment
hi
bricked my yoga c930-13ibk trying to downgrade it because processor was stuck at 400mhz and i read
in a forum that it was related to the latest bios version.
Yoga c930-13ibk B1C4
Serial Number: PF1EY9VA
MTM:81C40084PG
MO:PF9XB8A01153
Could you please help in order to tu pu it back to life?
Have a nice day
Regards
SeilaComment
post the contents of the bios chip even if it is corrupted..hi
MTM:81C40084PG
MO:PF9XB8A01153
Have a nice day
Regards
Seila
Every donation made will go towards server fees and maintenance costs.Comment
hello
backup of bios attached.
regards
Have a nice day
SeilaAttached FilesComment
Lenovo Yoga C930-13ikb main code NM-B741 S/N: PF1QO1J8 has burnt IC MP2949A. Firmware installed with new IC but it doesn't work. Anyone who has that Firmware, please give it to me. Thanks.Comment
Don't post pictures unless asked..
post the contents of the bios chip even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by AYsysHello dear forum members,
I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
Nothing was flashed here — the BIOS was only backed up.
I created the backup using a CH341A Black programmer and NeoProgrammer....-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by HotSaladMan*##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
Model : Lenovo ThinkBook 14S Yoga ITL
S/N : MP28JT19
MFG Date : 2022/02/09
Factory ID PRC4
MO : MPNXB26080FX
MTM : 20WE001US
MODULE FCC ID : PD9AX201NG
IC : 1000M-AX201NG
BOARD INFO
FLV34 LA-KO51P
REV : 1B 2020-08-24
Bit of Info
Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
chip id, so i would always uncheck the id check, so it would bypass the error
i did in fact make...-
- Loading...
