ASUS X540UV rev2.0 repaired bios
  • balobi
    • Jan 2015
    • 88
    • phillippines
    Kindly try and give feed back if it's work! thanks!
  • balobi
    • Jan 2015
    • 88
    • phillippines
    Re: ASUS X540UV rev2.0 repaired bios
    some body have schematic and boardview of ASUS x540UV rev 2.0 please help.
    my issue is hard disk not detected.
    • piernov
      • Jan 2016
      • 4435
      • France
      Wrong section.
      https://www.badcaps.net/forum/forumdisplay.php?f=40
      https://www.badcaps.net/forum/forumdisplay.php?f=41
        • 20318
        Thread moved to "BIOS Requests ONLY!"
        • dolunay79
          • Oct 2016
          • 18
          • turkey
          thanks
          • jimmyboyneutron
            • Feb 2021
            • 3
            • philippines
            asus x540uv rev,.2 good bios
            • huss584
              Hussein
              • Apr 2020
              • 225
              • Palestine
              Hello Everybody
              Need Help to Repair my BIOS Dump
              SN : J5N0GR04R52920A
              I try file on this thread but the ASUS logo take long time to appear and there is no SN on BIOS setup
              Attached Defect File :
              • shiyab
                • Sep 2023
                • 1235
                • india
                Originally posted by huss584
                Hello Everybody
                hi try
                • salawayon
                  • Nov 2012
                  • 568
                  • philippines
                  got one with no display issue...
                  infos:X540UV REV 2
                  SN: J5N0GR04Y89620B
                  thanks..
                    • 20318
                    infos:X540UV REV 2
                    SN: J5N0GR04Y89620B
                    thanks..
                    Post a picture of the barcode sticker if there is one
                    • salawayon
                      • Nov 2012
                      • 568
                      • philippines
                      sorry none... just attached the actual pictures. i tried the first posted file and it works but the nvidia GPU is missing. mine is a x540UB version. Any info how to copy DMI/winkey on this model, because i got a file with same version but with missing dmi/winkey? i tried DMICOPY but having an error, "line 11, error 1: invalid selection end"..
                        • 20318
                        The DMICOPY Tiny Hexer scripts are per machine, a script would only work if it had the same offsets. The offsets for this one are 240000 - 24FFFF
                        try this bios.
                        • salawayon
                          • Nov 2012
                          • 568
                          • philippines
                          try this bios.
                          it works.. thank you for the file and info..
                            SMDFlea commented
                            Editing a comment
                            You`re welcome
                        • thespaceman2000
                          • Jul 2024
                          • 6
                          • South Africa
                          Good Day
                          Please assist with removing the BIOS password from the attached file
                          ASUS X540UBR
                          Rev 2.0
                          S/N: LBN0CX10Y41046D
                          Thank You
                          • peste
                            • Dec 2016
                            • 12262
                            • ROMANIA
                            Originally posted by thespaceman2000
                            Good Day
                            ASUS X540UBR
                            Rev 2.0
                            Thank You
                            try..
                            admin password PENELOPE2001lee
                            boot password penelope2001LEE​
                            • shiyab
                              • Sep 2023
                              • 1235
                              • india
                              Good Day
                              ASUS X540UBR
                              Rev 2.0
                              Thank You
                              hi try
                              • thespaceman2000
                                • Jul 2024
                                • 6
                                • South Africa
                                Originally posted by shiyab
                                hi try
                                THANKSSSSSSS!!!!!! A MILLLLLLLION!!!!!
                                • ay_bulut
                                  • Feb 2016
                                  • 114
                                  • turkey
                                  ASUS X540uv rev 2.0 ram disable test done. working.
                                  • razor_amd
                                    by razor_amd
                                    12-15-2020, 07:07 PM
                                  • throwaway327
                                    by throwaway327
                                    Model No: RC72LA
                                    Serial No: SBNVKD001014459
                                    06-18-2025, 05:52 PM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • lrouw84
                                    by lrouw84
                                    Hi there,
                                    01-28-2023, 01:31 PM
                                  • DynaxSC
                                    by DynaxSC
                                    06-14-2024, 03:49 PM
