820-3787-a stuck on half installation
  • djems3
    • Nov 2014
    • 32
    • United Kingdom
    Hi.I'm attending to install OS on this mac ,which stuck on logo whit installation
    bar.After 5-10 min. goes in sleep mode.Starting after any pressed button but
    nothing on this screen.
    I've written another bios which i clean via Apple EFI patcher.
    I've tried from external hard and from internet both same.
    SSD is working ,i install it on another MAC .Here is my original bin.
    Can i have a help to solve the issue please.
    Thank you.
  • peste
    • Dec 2016
    • 12792
    • ROMANIA
    Re: 820-3787-a stuck on half installation
    Thank you.
    try..
    • djems3
      • Nov 2014
      • 32
      • United Kingdom
      Thank you for your answer.With this file is same.Stuck at middle.In 10 min screen goes off ,fans still spinning ,usb drive led is ON and nothing on the screen.10 min more goes off complete.
      • Ghamidi
        • Mar 2020
        • 303
        • France
        try
        https://www.badcaps.net/forum/showpo...79&postcount=8
        • djems3
          • Nov 2014
          • 32
          • United Kingdom
          Thank you for your answer.With this dump file getting slow cheam coming too late ,fans spins with max speed and nothing on the screen.Probably could be hardware issue but i don't have any clue what can be.
          • 5chematic
            • Jun 2019
            • 77
            Thank you.
            What was the main problem? ..what made you change the bios image?
            Advice, do not not go around downloading any bios.bin image that you find on the internet. Every mac have a unique architecture image on every chip.
            Some users unlock their mac's by using any image.bin they find on the internet. they unlock their mac's, but the results could end up in a overheating mac and many other problems. they won't be able to notice these problems, but in time they will regret it.
            For example, the following info is from the image that you posted:
            MacBook Pro (Retina, 15-inch, Mid 2014)
            Model: A1398
            EMC: 2881
            S/N: C02N6B******* Ireland, UK.
            Managment Engine: 9.0.5.1367
            Now, there is a bit of a difference from the image that peste shared than from the one you posted. The Managment Engine: 9.0.31.1487. it is not the same. with this you will be doing great damage to your mac.
            • piernov
              • Jan 2016
              • 4435
              • France
              You can use an SPI ROM dump from another Mac of the same board model number if you're sure it's good, but of course you have to clean the ME region properly (with Intel FITC and the correct ME region), replace the serial number and fix the Fsys checksum.
              And do 3x PRAM reset afterwards just for good measures.
              But obviously it's not the correct way to unlock these if that was the original intent.
              • djems3
                • Nov 2014
                • 32
                • United Kingdom
                It came with this problem.It wasn't water damaged or any repairs on it.I did
                ME region clean fallowing your instructions on the youtube video.
                When i'm checking my original dump how as you mentioned on flashimage tool i have some error and yelow marked row "BOOT GUARD PROFILE CONFIGURATION " is unknown maybe this is not normal to be.I'm sending pictures of the errors.Thank you.
                • peste
                  • Dec 2016
                  • 12792
                  • ROMANIA
                  post the full name and model of the laptop ..EMC and serial number on the case ...
                  • 5chematic
                    • Jun 2019
                    • 77
                    peste, all the info is on post #6
                    Unless the image he posted here is not from his actual mac but from another similar mac image he found on the internet.
                    Now, if I was djems3 I would follow piernov suggestion.
                    • 5chematic
                      • Jun 2019
                      • 77
                      Let me ask you.. what did you do with the image that you dumped from your mac? do you still have a backup of it?
                      • djems3
                        • Nov 2014
                        • 32
                        • United Kingdom
                        Yes i have the original dump i kept it always on different place with the name from RT809
                        plus motherboard serial from label on motherboard.
                        Here is the model A1398 emc 2881 s/n C02N6BXXG3QD.
                        Thank you.
                        • peste
                          • Dec 2016
                          • 12792
                          • ROMANIA
                          yes i have the original dump i kept it always on different place with the name from rt809
                          Here is the model a1398 emc 2881 s/n c02n6bxxg3qd.
                          Thank you.
                          try..
                          • djems3
                            • Nov 2014
                            • 32
                            • United Kingdom
                            Same no any changes.Thank you.
                              • 20888
                              Try this one .
                              • piernov
                                • Jan 2016
                                • 4435
                                • France
                                It's not necessarily an EFI/ME region problem.
                                • djems3
                                  • Nov 2014
                                  • 32
                                  • United Kingdom
                                  Same .Thank you .Applesupport.com/-5101f from internet
                                  and half installation from external hard.
                                  • Wachenaggo
                                    • Jul 2018
                                    • 66
                                    • Philippines
                                    came across this one the problem is the SMC balls being detached on the ME bootstrap circuit. not enabling ME in the BIOS. check ME Bootstrap also.
                                    • Rashid36
                                      • Aug 2014
                                      • 59
                                      • Saudi Arabia
                                      Dear Need Bios For A1398 emc 2745 Late 2013, Some one our write Original bios,
