820-3787-a stuck on half installation
  • djems3
    • Nov 2014
    • 32
    • United Kingdom
    Hi.I'm attending to install OS on this mac ,which stuck on logo whit installation
    bar.After 5-10 min. goes in sleep mode.Starting after any pressed button but
    nothing on this screen.
    I've written another bios which i clean via Apple EFI patcher.
    I've tried from external hard and from internet both same.
    SSD is working ,i install it on another MAC .Here is my original bin.
    Can i have a help to solve the issue please.
    Thank you.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: 820-3787-a stuck on half installation
    Thank you.
    try..
    • djems3
      • Nov 2014
      • 32
      • United Kingdom
      Thank you for your answer.With this file is same.Stuck at middle.In 10 min screen goes off ,fans still spinning ,usb drive led is ON and nothing on the screen.10 min more goes off complete.
      • Ghamidi
        • Mar 2020
        • 306
        • France
        try
        https://www.badcaps.net/forum/showpo...79&postcount=8
        • djems3
          • Nov 2014
          • 32
          • United Kingdom
          Thank you for your answer.With this dump file getting slow cheam coming too late ,fans spins with max speed and nothing on the screen.Probably could be hardware issue but i don't have any clue what can be.
          • 5chematic
            • Jun 2019
            • 77
            Thank you.
            What was the main problem? ..what made you change the bios image?
            Advice, do not not go around downloading any bios.bin image that you find on the internet. Every mac have a unique architecture image on every chip.
            Some users unlock their mac's by using any image.bin they find on the internet. they unlock their mac's, but the results could end up in a overheating mac and many other problems. they won't be able to notice these problems, but in time they will regret it.
            For example, the following info is from the image that you posted:
            MacBook Pro (Retina, 15-inch, Mid 2014)
            Model: A1398
            EMC: 2881
            S/N: C02N6B******* Ireland, UK.
            Managment Engine: 9.0.5.1367
            Now, there is a bit of a difference from the image that peste shared than from the one you posted. The Managment Engine: 9.0.31.1487. it is not the same. with this you will be doing great damage to your mac.
            • piernov
              • Jan 2016
              • 4439
              • France
              You can use an SPI ROM dump from another Mac of the same board model number if you're sure it's good, but of course you have to clean the ME region properly (with Intel FITC and the correct ME region), replace the serial number and fix the Fsys checksum.
              And do 3x PRAM reset afterwards just for good measures.
              But obviously it's not the correct way to unlock these if that was the original intent.
              • djems3
                • Nov 2014
                • 32
                • United Kingdom
                It came with this problem.It wasn't water damaged or any repairs on it.I did
                ME region clean fallowing your instructions on the youtube video.
                When i'm checking my original dump how as you mentioned on flashimage tool i have some error and yelow marked row "BOOT GUARD PROFILE CONFIGURATION " is unknown maybe this is not normal to be.I'm sending pictures of the errors.Thank you.
                • peste
                  • Dec 2016
                  • 13924
                  • ROMANIA
                  post the full name and model of the laptop ..EMC and serial number on the case ...
                  • 5chematic
                    • Jun 2019
                    • 77
                    peste, all the info is on post #6
                    Unless the image he posted here is not from his actual mac but from another similar mac image he found on the internet.
                    Now, if I was djems3 I would follow piernov suggestion.
                    • 5chematic
                      • Jun 2019
                      • 77
                      Let me ask you.. what did you do with the image that you dumped from your mac? do you still have a backup of it?
                      • djems3
                        • Nov 2014
                        • 32
                        • United Kingdom
                        Yes i have the original dump i kept it always on different place with the name from RT809
                        plus motherboard serial from label on motherboard.
                        Here is the model A1398 emc 2881 s/n C02N6BXXG3QD.
                        Thank you.
                        • peste
                          • Dec 2016
                          • 13924
                          • ROMANIA
                          yes i have the original dump i kept it always on different place with the name from rt809
                          Here is the model a1398 emc 2881 s/n c02n6bxxg3qd.
                          Thank you.
                          try..
                          • djems3
                            • Nov 2014
                            • 32
                            • United Kingdom
                            Same no any changes.Thank you.
                              • 22293
                              Try this one .
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                It's not necessarily an EFI/ME region problem.
                                • djems3
                                  • Nov 2014
                                  • 32
                                  • United Kingdom
                                  Same .Thank you .Applesupport.com/-5101f from internet
                                  and half installation from external hard.
                                  • Wachenaggo
                                    • Jul 2018
                                    • 66
                                    • Philippines
                                    came across this one the problem is the SMC balls being detached on the ME bootstrap circuit. not enabling ME in the BIOS. check ME Bootstrap also.
                                    • Rashid36
                                      • Aug 2014
                                      • 65
                                      • Saudi Arabia
                                      Dear Need Bios For A1398 emc 2745 Late 2013, Some one our write Original bios,
                                      • Stunt
                                        Hp Laptop Stuck on Hp protected by hp sure start screen
                                        by Stunt
                                        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                        screen that's it and stuck there. I left it until the following day and i still...
                                        09-02-2025, 01:51 PM
                                      • stormanimal83
                                        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                        by stormanimal83
                                        Hey....
                                        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                        01-18-2024, 02:15 PM
                                      • ekozeko333
                                        [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                        by ekozeko333
                                        I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                        🔥 The Problem Started After Suspected ESD/PD Fault
                                        I experienced a power issue or ESD event through a USB-C charger
                                        After that, the NX20P5090 power switch was visibly burned and was replaced
                                        Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                        🧠 What I’ve Done So Far
                                        Flashed...
                                        06-21-2025, 02:48 AM
                                      • praveenramavath
                                        Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                        by praveenramavath
                                        Hello All,
                                        I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                        https://www.hifivision.com/threads/m...-screen.98243/
                                        Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                        04-26-2025, 09:08 AM
                                      • Raulnn
                                        TD Systems K50DLG12US half black and half white screen
                                        by Raulnn
                                        good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                        By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                        01-20-2024, 04:49 PM
