Lenovo E145 DALI2KMB8D0 REV D Bios dump need!
  • Ariu
    • Dec 2020
    • 133
    Hello ,
    i need a bios dump for this motherboard
    DALI2KMB8D0 REV D.
    It is a Lenovo E145 .
    Please help.
  • peste
    • 13199
    • ROMANIA
    Re: Lenovo E145 DALI2KMB8D0 REV D Bios dump need!
    Originally posted by Ariu
    Hello ,
    DALI2KMB8D0 REV D.
    Please help.
    post the backup of the bios
    • Ariu
      • Dec 2020
      • 133
      thanks for your reply....
      • Ariu
        • Dec 2020
        • 133
        Thank you i have attached the bios files below.
        • peste
          • 13199
          • ROMANIA
          bios extracted from the Lenovo site update.
          DMI FF40-1000F
          • Ariu
            • Dec 2020
            • 133
            DMI FF40-1000F
            Thank you.
            Is this bios for Lenovo E145 DALI2KMB8D0 REV D compatible?
            • Zibbo
              • Mar 2017
              • 203
              • Zimbabwe
              DMI FF40-1000F
              Thank you, working
              • mainah njoroge
                • Aug 2017
                • 36
                • kenya
                Originally posted by zibbo
                thank you, working
                are you shure this file worked for you
                isnot coplete
                • dahnking
                  • Apr 2018
                  • 259
                  • kenya
                  DMI FF40-1000F
                  working tested
                  • almussafer
                    • Jun 2019
                    • 74
                    • Iraq
                    you can try this one i upload the original bios with password and the patched bios from autopatcher program and its worked 100%
                    • AHmad_Salal
                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                      by AHmad_Salal
                      Hello all,
                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                      11-28-2023, 05:28 AM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • hyperwood
                      [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                      by hyperwood
                      I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                      The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                      I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                      āœ… What I need:
                      • A working 2MB BIOS dump
                      • Matching NM-E471 Rev. 2.0, e.g. JY575
                      06-25-2025, 02:28 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Joluvillas
                      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                      by Joluvillas
                      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                      06-18-2024, 10:35 PM
