Dell Precision 5520 bios password
  • olegzum
    • Apr 2018
    • 10
    • Ukraine
    #101
    Originally posted by hoaca388
    Click image for larger version  Name:	2025-04-05 16_24_49-BIOS Master Password Generator for Laptops.png Views:	0 Size:	19.3 KB ID:	3608230
    Unfortunately, these passwords do not work.
    • lapfix
      • Mar 2020
      • 2765
      • my workshop
      #102
      Originally posted by olegzum
      Dell Precision 5520, LA-E331p rev 2.0, S/T: 8FLH0N2
      password prompt code: 8FLH0N2-E7A8
      #99
      • olegzum
        • Apr 2018
        • 10
        • Ukraine
        #103
        Dear lapfix, thank you very much for your help. The password has been removed. You are a better specialist than me. I periodically encounter the need to remove the password. Can you tell me where I can read how you do it - remove the password from the BIOS dump
        • lapfix
          • Mar 2020
          • 2765
          • my workshop
          #104
          Easy..compare th 2 bios and you will find the way.
          save it and do the same with other suffix
          • olegzum
            • Apr 2018
            • 10
            • Ukraine
            #105
            Thank you again!!!!
            • MO_SAIED
              MEMBER
              • Oct 2024
              • 4
              • India
              #106
              hii plz you help me all badcaps user we have a system dell 5520 with admin password plz some can give me bios file without service tag like a configure bios file
                • 22209
                Type the laptop service tag, full name and model, motherboard model, etc.
                post the contents of the bios chip even if it is corrupted..
                read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                • abbaswali
                  • Jun 2025
                  • 3
                  • United Kingdom
                  #108
                  can someone help with the bios admin password reset please
                  4HVSVG3-8FC8
                  thanks
                  • lapfix
                    • Mar 2020
                    • 2765
                    • my workshop
                    #109
                    where's the bios
                    • abbaswali
                      • Jun 2025
                      • 3
                      • United Kingdom
                      #110
                      where's the bios
                      sorry what do I need to do to get the bios details?
                      • lapfix
                        • Mar 2020
                        • 2765
                        • my workshop
                        #111
                        A hot air+ programmer+some skills
                        • abbaswali
                          • Jun 2025
                          • 3
                          • United Kingdom
                          #112
                          please reshare a link to help
                          does this need a device too (seen in some videos)
                          • BlackListedMorph
                            • Jun 2025
                            • 3
                            • Portugal
                            #113
                            Hi there,
                            I have a problem with a BIOS password:
                            Precision Dell 5520
                            CVSSLH2-E7A8
                            I followed the "BIOS guides, methods, resources and tools" guide, but the passwords that the https://bios-pw.org/ gives me dont work:
                            Can you help?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12426
                              #114
                              Originally posted by BlackListedMorph
                              Hi there,
                              Precision Dell 5520
                              CVSSLH2-E7A8
                              Click image for larger version  Name:	image.png Views:	0 Size:	27.2 KB ID:	3669209
                              Can you help?
                              3.4. Dell
                              Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                              See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                              Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                              Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                              Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                              Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                              Note: There is no publicly available 8FC8 generator available at the moment.
                              The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                              8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                              • BlackListedMorph
                                • Jun 2025
                                • 3
                                • Portugal
                                #115
                                hoaca388 thank you for your response, but i dont understand what you are trying to say.
                                You just reposted the "BIOS guides, methods, resources and tools" guide section for Dell, and exactly what i all ready tried.
                                I have a 5520 with a E7A8 suffix, but the password that is generated in the https://beta.bios-pw.org/ is not working, and i have tried every variant of "enter" or "ctrl+enter+enter" etc, that i could think off, with no luck.
                                Allways the same password error. Tried also with those other sufifixs just for kicks, but the same.
                                Is there any other way to get the password?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12426
                                  #116
                                  The keyboard to enter the password must be US qwerty type.
                                  • samipropc
                                    • Jun 2025
                                    Hi I need password for dell latitude 5520 serial 3MYDJG3-8FC8
                                    THANK YOU
                                      • 22209
                                      THANK YOU
                                      https://www.badcaps.net/forum/troubl...rces-and-tools
                                      • djamil-sw
                                        • Jul 2019
                                        • 3
                                        • algeria
                                        #119
                                        hello . i have corrupted bios file . i guess my programmer didnt read the bios propperly . its dell latItude 5520 . service tag CT0HGG3 . i tried to write an other files but . its stuck on dell logo . i need help to rebuild the original bios .
                                        • yeoltk
                                          • Jul 2025
                                          • United States of America
                                          #120
                                          I need a password for the bios.
                                          I got 7QLWFG3-8FC8.
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            11-08-2025, 10:04 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • trix11
                                            Dell Precision T1650 MT Workstation bricked after BIOS update
                                            by trix11
                                            I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                                            - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                                            - Dell Precision T1650 mid tower Workstation
                                            - Xeon E3-1225 V2
                                            - 32Gb PC3-12800E RAM
                                            - 4Tb SATA HDD
                                            - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                                            I see now that others have experienced like issues e.g.:
                                            - https://www.dell.com/community/Prec...
                                            10-24-2022, 10:35 PM
                                          • markenero3
                                            HELP Dell Precision 3480 Bios Password with absolute enabled
                                            by markenero3
                                            Good Day Everyone please help! I have Dell precision 3480 13th gen with Bios password and absolute enable. I already tried 8FC8 Patcher it works but the absolute still cannot be disabled
                                            Here is my Orig bios file with Bios password and Absolute Enabled
                                            Board: IDB40 LA-M402P
                                            Service Tag : HFZW724
                                            Thank you So much in advance....
                                            02-20-2025, 11:23 AM
                                          • MMH3
                                            Dell Precision 3450 small form factor - BIOS cannot be opened in FIT - please help clean
                                            by MMH3
                                            i would appreciate, if someone could help me.
                                            DELL: 3450 sff
                                            Servicetag: (!) obviously FAKE - ABC2345
                                            Mainboard: 0GK35Y - serial /ABC2345/CNFCW0023800L6/
                                            Chipset: Intel W580 (Rocket Lake PCH-H)
                                            BIOS: 1.34.1
                                            ME: 15.0.50.2633
                                            mor data can be found the HW-Info-data in the rar-file
                                            I have this BIOS from a DELL Precision 3450 SmallFormFactor mainboard i bought refurbished.. from china.
                                            The board itself works without any issues.
                                            My goal was to clean the ME of this and fully...
                                            09-13-2025, 11:54 PM
