Lenovo X1 Carbon 7th Gen 20QD Bios
  • Ariu
    • Dec 2020
    • 138
    Hello everybody, i need a good bios for this device or the backup repaired.
    Lenovo Thinkpad X1 Carbon: Type 20QE-SAY601
    S/N: PF-1W6Z7X
    the device is coming on but no display either with an external monitor, capslock is working.
    thanks.
    • peste
      peste commented
      Editing a comment
      merged post
  • ghostlp.ls
    • Jul 2022
    • 11
    • portugal
    Good afternoon, my Lenovo Thinkpad turns on but it doesn't show the image, nor on the external monitor and capslook doesn't work either.
    Everything indicates that the bios is damaged, can you help me fix it?
    I tried the bios from post #19 and now the power button flashes 3 times when connecting the charger and does nothing else.
    I appreciate help
    lenovo FX490 NM-B861 Rev: 1.0 (2019-03-28)
    serial: PF-1DJ1SV
    type: 20QD-CT01WW
    obrigado
    thanks
    • Gangubasus
      • Aug 2024
      • 21
      • Russia
      Hello! Help fix BIOS when turning on power button blinks 3 times.
      Lenovo thinkpad carbon 7gh
      20QD002XRT
      PF-226BW0
      • Gangubasus
        • Aug 2024
        • 21
        • Russia
        20QD002XRT
        PF-226BW0
        The BIOS from post #19 works fine, but when you enable the update from Windows or from a bootable USB flash drive, an error window appears Click image for larger version
        • hoaca388
          Badcaps
          • Jan 2022
          • 12419
          The BIOS from post #19 works fine, but when you enable the update from Windows or from a bootable USB flash drive, an error window appears Click image for larger version  Name:	1745129506241.jpg Views:	0 Size:	1.99 MB ID:	3618984
          X1 Carbon 7th Gen - Laptop (ThinkPad) - Type 20QD
          • Gangubasus
            • Aug 2024
            • 21
            • Russia
            #26
            Thanks, friend! But with your BIOS it doesn't turn on either. When you connect the power, the power button blinks 3 times and nothing else happens.
            • EagleTG
              • Jun 2011
              • 21
              #27
              Greetings all, working on an X1 Carbon 7th Gen model 20QD with board FX-490 NM-B861 Rev 1.0
              Type: 20QD-001VUS
              Serial: PF-1DZRD0
              Facing an issue where the laptop is completely dead (no LEDs, no power at all, no fan spin). I do not have an image of the current corrupted BIOS as the chip won't read in my reader. Confirmed that the chip has pins 3 and 4 shorted, may have been my fault as I fumbled with a SOIC-8 Clip, not entirely sure. I ordered replacement chips from Digikey and would like an image to flash to them if possible.
              • TylerHyde21
                Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                by TylerHyde21
                Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                06-29-2024, 10:38 AM
              • MaxonDomkrat
                Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                by MaxonDomkrat
                Hi everyone.
                I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                07-30-2025, 01:27 PM
              • lucaszmn
                by lucaszmn
                Problem:
                Initial Findings:
                • I concluded that the
                08-12-2025, 03:01 PM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • grimacelord
                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                by grimacelord
                Hello there.
                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                History:
                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                I searched for this error online and discovered...
                03-15-2023, 03:29 PM
