Lenovo X1 Carbon 7th Gen 20QD Bios
  • Ariu
    • Dec 2020
    • 133
    Hello everybody, i need a good bios for this device or the backup repaired.
    Lenovo Thinkpad X1 Carbon: Type 20QE-SAY601
    S/N: PF-1W6Z7X
    the device is coming on but no display either with an external monitor, capslock is working.
    thanks.
    • peste
      peste commented
      Editing a comment
      merged post
  • ghostlp.ls
    • Jul 2022
    • 8
    • portugal
    Good afternoon, my Lenovo Thinkpad turns on but it doesn't show the image, nor on the external monitor and capslook doesn't work either.
    Everything indicates that the bios is damaged, can you help me fix it?
    I tried the bios from post #19 and now the power button flashes 3 times when connecting the charger and does nothing else.
    I appreciate help
    lenovo FX490 NM-B861 Rev: 1.0 (2019-03-28)
    serial: PF-1DJ1SV
    type: 20QD-CT01WW
    obrigado
    thanks
    • Gangubasus
      • Aug 2024
      • 17
      • Russia
      Hello! Help fix BIOS when turning on power button blinks 3 times.
      Lenovo thinkpad carbon 7gh
      20QD002XRT
      PF-226BW0
      • Gangubasus
        • Aug 2024
        • 17
        • Russia
        20QD002XRT
        PF-226BW0
        The BIOS from post #19 works fine, but when you enable the update from Windows or from a bootable USB flash drive, an error window appears Click image for larger version
        • hoaca388
          Badcaps
          • Jan 2022
          • 11653
          The BIOS from post #19 works fine, but when you enable the update from Windows or from a bootable USB flash drive, an error window appears Click image for larger version  Name:	1745129506241.jpg Views:	0 Size:	1.99 MB ID:	3618984
          X1 Carbon 7th Gen - Laptop (ThinkPad) - Type 20QD
          • Gangubasus
            • Aug 2024
            • 17
            • Russia
            #26
            Thanks, friend! But with your BIOS it doesn't turn on either. When you connect the power, the power button blinks 3 times and nothing else happens.
            • TylerHyde21
              Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
              by TylerHyde21
              Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
              I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
              I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
              This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
              06-29-2024, 10:38 AM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
            • grimacelord
              Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
              by grimacelord
              Hello there.
              I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
              History:
              1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
              I searched for this error online and discovered...
              03-15-2023, 03:29 PM
            • Gangubasus
              lenovo thinkpad x1 carbon gen 12 bios damp
              by Gangubasus
              Model 21KC-FVT001
              S/N PF-4CQ9FG
              CPU genuine intel(r) cpu 0000
              BIOS N3YET06C (0.06)
              Hello! I need help getting a modified BIOS for my system. Since I have an engineering processor, is it possible to add the microcode of this engineering processor to the latest BIOS for this laptop model? I think since the BIOS is old, that's why the Wi-Fi driver is not installed on Win10 and Win11, the sound is not adjusted (error code 10 in the device manager) and the screen brightness. The laptop also has BIOS chips W25Q512NW and W25Q128JV, how can...
              03-01-2025, 01:25 AM
            • erico
              Lenovo X1 Carbon BIOS not getting voltage
              by erico
              First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
              I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
              So far these are my diagnostics:
              When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
              When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
              If i plug the battery...
              05-02-2024, 02:40 AM
