Lenovo bios V330-15IKB
  • Sergey Buldakov
    • Dec 2024
    • 5
    • saint-petersburg
    #101
    Originally posted by peste
    DMI 201000 - 2011FF
    Please excuse my ignorance. You can go into a little more detail. I took it from the old firmware (screenshot) this is the part that I inserted into the firmware from post#31.​ but the serial and MTM did not appear.
    • Sergey Buldakov
      • Dec 2024
      • 5
      • saint-petersburg
      #102
      DMI 201000 - 2011FF
      Thank you. Everything worked out.
      • chaker752000
        • Mar 2016
        • 44
        • tunis
        #103
        Re: Lenovo bios V330-15IKB
        try..
        THANKS WORKING PERFECTLY 100%
        • Ven
          • Jul 2016
          • 46
          Hello ! I need BIOS for my Lenovo V330-15IKB please. Details are :
          • Lenovo V330 - 15IKB
          • Model Name : 81AX
          • S/N : R90QBX1V
          • MTM : 81AX00ARUK
          • MO : R9N0B832301K
          • Motherboard : LV315KB MB
          • Motherboard : 17807-3
          • Motherboard : 448.0DC05.0031
          • hoaca388
            Badcaps
            • Jan 2022
            • 11835
            #105
            • Model Name : 81AX
            • S/N : R90QBX1V
            • MTM : 81AX00ARUK
            • MO : R9N0B832301K
            V330-15IKB Laptop (Lenovo) - Type 81AX
            • Ven
              • Jul 2016
              • 46
              Thanks. For the record, my laptop still doesn't work. The Power and Caps Lock lights are solid on, the CPU fan gradually reaches full speed, and the main power line is at 8.7V without the battery. I wanted to rule out the possibility that it's a BIOS issue.
              • flikz
                • Mar 2025
                • 8
                • lebanon
                #107
                Hello good people, i need help clearing the bios pass from this dump thanks in advanced <3
                • peste
                  peste commented
                  Editing a comment
                  post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
              • peste
                • 12887
                • ROMANIA
                #108
                post S/N, full name and model, motherboard model, TYPE,etc.
                read the forum rules..
                https://www.badcaps.net/forum/troubl...ore-posting​
                • flikz
                  • Mar 2025
                  • 8
                  • lebanon
                  #109
                  Lenovo V330-15IKB
                  Model Name: 81AX
                  Mfg Date: 19/03/28
                  S/N: R90TNC2V
                  MTM: 81AX001BAK
                  I was able to fix my bios with using a clean bios from here https://www.badcaps.net/forum/troubl...30-15ikb/page5 annd then moving the DMI region to the new.bin file i'll attach it just in case some1 needs it
                  and thank u peste for pointing out the missing requirments i think the post needs to be merged too again sorry for that
                  • jhonca
                    • Oct 2022
                    • Argentina
                    #110
                    Hi. Can you please fix bios for :
                    Lenovo v330-15IKB
                    Type model :81AX
                    SERIAL : R90SH3Q9
                    MTM:81AX000DAR
                    MO;R9N0B8B26018
                    Hello friends, recently I have read the post flashed some rom, but none has worked for me because of the issue of the slow start of ignition, because it takes 25 seconds, the installed firm does not have a serial number or anything, even if I install some other firm when starting the bios no serial number or model appears in the info of the bios, for this I attach the bios in question, I have tried to edit but I have stayed in the attempt, for this due to your mastery I request your consideration and help and I request a new bios, greetings from Argentina.
                    Thank You.​
                    • peste
                      • 12887
                      • ROMANIA
                      #111
                      Lenovo v330-15IKB
                      Type model :81AX
                      SERIAL : R90SH3Q9
                      MTM:81AX000DAR
                      MO;R9N0B8B26018
                      Thank You.​
                      try post #2,30...
                      • reparacipo
                        • Jun 2018
                        • 30
                        • argentina
                        #112
                        Hi, could you fix this BIOS for me? I have a black screen.
                        Lenovo V330-15IKB
                        MODEL: 81AX
                        SERIES: R90SET0F​
                          • 21058
                          Lenovo V330-15IKB
                          MODEL: 81AX
                          SERIES: R90SET0F​
                          Bios + DMI. Your model 81AX000GAR shipped with no OS .https://psref.lenovo.com/Detail/Leno...B?M=81AX000GAR
                          • reparacipo
                            • Jun 2018
                            • 30
                            • argentina
                            #114
                            Thanks for the BIOS, but I'm having the same problem. All the coils are properly powered. Do you have another BIOS?
                              • 21058
                              The one i posted is a virgin bios plus your DMI. There are many other working bios versions in this thread. Attach everything to motherboard, daughter bioards,if any , everything apart from the screen. Check via HDMI. It could be a hardware proble, maybe the soldered ram. You can try disabling the ram yourself - https://www.badcaps.net/forum/troubl...20#post3232220
                              • reparacipo
                                • Jun 2018
                                • 30
                                • argentina
                                #116
                                Indeed, there is a problem with the Omboar RAM, I disabled it and it started working normally, thank you very much
                                • Iamjeeepoy
                                  • Mar 2025
                                  • Philippines
                                  #117
                                  Hello Masters. can you fix this bios? laptop turns on with capslock on but blackscreen only.
                                  Lenovo V330-15IBK
                                  SN: R90SAC3K
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11835
                                    #118
                                    Lenovo V330-15IBK
                                    SN: R90SAC3K
                                    • Iamjeeepoy
                                      • Mar 2025
                                      • Philippines
                                      #119
                                      Hi Boss. Thank you for your response. I tried flashing this file but still getting blank screen result. Also caps are still on.
                                      • SoporteNetFe
                                        • Aug 2021
                                        • 117
                                        • Argentina
                                        #120
                                        Orig+6SCN54WW+outimage.rar (4.60 MB)
                                        try..
                                        This file works for me. Only need put my DMI info ( DMI 201000 - 2011FF ).
                                        This BIOS have ME version 11.8.50.3399, updated successful to 11.8.86.3877 with package from Lenovo.
                                        Thanks!
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          by grimacelord
                                          Hello there.
                                          History:
                                          03-15-2023, 03:29 PM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
