Lenovo Thinkpad T480 BIOS and EEPROM request
    Re: Lenovo Thinkpad T480 BIOS and EEPROM request
    Originally posted by LenBios View Post
    Please try...
    Thanks, I was able to revive my notebook with that image.
      Re: Help please Lenovo T480S Bios Password
      I have lenovo thinkpad T480 with bios password. please help
        See post #15
        BIOS guides, methods, resources and tools
        Password removal by laptop brand
        Become a Badcaps supporter
        Thanks to all supporters.
          I can not.
          please help
            I can not.
            please help
            Originally posted by piernov View Post
            Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
              I managed to create the pach file. I am trying. I will give information
                Good for you. Before that, make sure your factory dump is properly read, use verification. Read the chip several times and compare the contents.
                  When flashing a BIOS always make a backup first. Take 2 or 3 different dumps and make sure they are identical.
                  On Windows, you can use the command "fc /b" to check if two dumps are identical.
                  Make sure that the dumps looks good, i.e. not filled with 0x00 or 0xFF. After compression, if the file has a size of only a few kilobytes, the EEPROM was most likely not read properly.
                  Additionally, please read the FAQ at: https://www.badcaps.net/forum/showthread.php?t=98665
                    is this true. bios contents look the same
                    i guess it didn't
                      You did not understand me correctly. I meant the factory (ie original) dump.
                      Read the chip with your factory dump several times, and compare the contents. To make sure you have a reliable backup first.
                      Edit: I don't understand why you are in such a hurry.
                      Read carefully what I replied to you and then proceed with the patching of the dump.
                        I finally made it. Thank you for the help
                          You're welcome. Good job!
                          Please consider donation in support of the "Bios Requests" section of the forum.
                            I have Lenovo T480 with absolute enabled on the bios. I flashed with the patched bios it boots up but will stuck forever at entering setup and can't get to bios.
                            Can anyone help me with this issue?
                            I attached both original and patch dump.
                              Originally posted by knguyenfl View Post
                              You have Absolute enabled in the bios, but not bios password, or you have both enabled?
                                Hi Vesko,
                                just absolute enabled only, no bios password.
                                  Hi Vesko,
                                  In this case flash back your original dump, power up the laptop then enter the bios and set supervisor password, restart, power off, dump the bios chip again and then patch the dump. Follow the "how to use the patch" steps.
                                  After that you can be able to disable Absolute.
                                    Absolute disabled, thank you so much for your help.
                                      You're welcome.
                                        clear me display
                                          screen comes on in 60 seconds. can you clear me area for me
