hp 450 g7 password
please help me to remove bios pasword
thanks
sr :5CD10891PDComment
can help to unlock this bios password?
i had try using rcunlocker , but still same.
here is the bios file.
HP probook 450 G7
s/n -JPH0416RT4
board - DA0X8MMB6D0 REV
THANKSAttached FilesComment
Hi there,
I have an HP ProBook 450 G7 that needs the BIOS password removed. I see it's possible to request this here?
What do you need from me to assist?
Thank you,
SpectreComment
- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
https://www.badcaps.net/donateComment
I would ask for assistance. I am getting a "HP endpoint security controller problem" error on boot - Laptop then boots normally. I tried updating bios, resetting security defaults and bios defaults but the error on boot persists. It is a replacement board, the original board had a shorted CPU. I am attaching both EC and main BIOS dumps.
HP ProBook 450 G7
Board: DA0X8MMB6D0 Rev: D
Model: X8M-6L
Many thanks.Attached FilesComment
HP ProBook 450 G7
Model: X8M-6L
Many thanks.
https://www.badcaps.net/forum/troubl...er#post3310855Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hi I need some help im trying to programm bios for HP ProBook 450 G7, board DAOX8MMB6D0 , there's no bios backup
I downloaded a few dumps from here, but programmer gets stuck when flashing, i tried asprogrammer, neoprogrammer both same issue
I can read chip with ch341 bur can't erase or write, any idea with this ? chip is 25B127DSIG
Thanks in advance
The bios of laptop is password protected.
Made backup from both chip, patched the winbond with RCUnlocker, flashed it back and the laptop does not start.
The power light turns white and blinking 5 or 6 times orange. Screen stays black.
Tried to flash back the original backup, problem stays.
What did I do wrong?
HP ProBook 450 G7
6YY26AV
5CD106FHSQ
MB model: X8M-6L
Any help is appriciated!Comment
HP ProBook 450 G7
6YY26AV
5CD106FHSQ
MB model: X8M-6L
Any help is appriciated!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
Hey guys,
have a laptop here that has a supervisor Password (dump in Attachements).
Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
the laptop works but everytime it wants me to type a supervisor password i never set.
I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
Anyway i wanted to ask what of the two chips is the ec bios because on the left...-
Channel: BIOS Requests ONLY!
by mferna14Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...05-13-2025, 04:16 PM
by Badpatch02Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...-
by Johnny hHello,
I'm hoping someone can assist me.
I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
It still boots into Windows (boots from whatever SSD is installed but not from USB).
The model number is M7600R and serial number is N8N0CX03H71131C.
I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
Code:tmNx\'=QJQ
by coolshrimpHere is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
See Diagram for Wiring.
Use MEC-1633#ISP on your RT809h
This is same Jtag pinout and method for T490S/X390
(But your R/W 10K Resistor Location May In a Different Location)
MEC-Chips Store Bios Password In a Secure Un-Editable Area
Following steps clear that secure area to re-initialize itself to default (Blank)
- Loading...
