hp 450 g7 password
  • Dihpez
    • Jul 2024
    • 8
    • The Netherlands
    #161
    Originally posted by shiyab
    post snid
    SN# 5CD1102DD7
  • techrecycle
    • Jan 2024
    • 57
    • england
    #162
    please help me to remove bios pasword
    thanks
    sr :5CD10891PD
      • 21682
      thanks
      sr :5CD10891PD
      https://www.badcaps.net/forum/troubl...43#post3672143
      • dreamsteven123
        • Apr 2023
        • 34
        • Malaysia
        #164
        can help to unlock this bios password?
        i had try using rcunlocker , but still same.
        here is the bios file.
        HP probook 450 G7
        s/n -JPH0416RT4
        board - DA0X8MMB6D0 REV
        THANKS
        • dreamsteven123
          • Apr 2023
          • 34
          • Malaysia
          #165
          HP probook 450 G7
          s/n -JPH0416RT4
          THANKS
          i solve it already , thanks
          • spectre_SB
            • Sep 2025
            • Grand Cayman
            #166
            Hi there,
            I have an HP ProBook 450 G7 that needs the BIOS password removed. I see it's possible to request this here?
            What do you need from me to assist ?
            Thank you,
            Spectre
            • hoaca388
              Badcaps
              • Jan 2022
              • 12272
              #167
              Originally posted by spectre_SB
              Hi there,
              Thank you,
              Spectre
              You MUST:
              • Read BIOS guides, methods, resources and tools
              • Try the method at BIOS guides, methods, resources and tools before requesting help
              • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
              • Use search function in case someone already answered your request
              • Post under a related thread if it exists
              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
              • Name your thread with make, full model numbers and request
              • Provide a BIOS/EC dump if possible
              • Attach files directly to your post instead of linking to external websites
              • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
              ​https://www.badcaps.net/donate
              • nemogoce
                • Nov 2023
                • Slovenia
                #168
                I would ask for assistance. I am getting a "HP endpoint security controller problem" error on boot - Laptop then boots normally. I tried updating bios, resetting security defaults and bios defaults but the error on boot persists. It is a replacement board, the original board had a shorted CPU. I am attaching both EC and main BIOS dumps.
                HP ProBook 450 G7
                Board: DA0X8MMB6D0 Rev: D
                Model: X8M-6L
                Many thanks.
                • peste
                  • 13436
                  • ROMANIA
                  #169
                  HP ProBook 450 G7
                  Model: X8M-6L
                  Many thanks.
                  try...
                  https://www.badcaps.net/forum/troubl...er#post3310855
                  • DAVIDREYEST
                    • Sep 2025
                    • 5
                    • México
                    #170
                    Hi I need some help im trying to programm bios for HP ProBook 450 G7, board DAOX8MMB6D0 , there's no bios backup
                    I downloaded a few dumps from here, but programmer gets stuck when flashing, i tried asprogrammer, neoprogrammer both same issue
                    I can read chip with ch341 bur can't erase or write, any idea with this ? chip is 25B127DSIG
                    Thanks in advance
                    • buglerbalint
                      • Aug 2021
                      • 20
                      • Austria
                      #171
                      The bios of laptop is password protected.
                      Made backup from both chip, patched the winbond with RCUnlocker, flashed it back and the laptop does not start.
                      The power light turns white and blinking 5 or 6 times orange. Screen stays black.
                      Tried to flash back the original backup, problem stays.
                      What did I do wrong?
                      HP ProBook 450 G7
                      6YY26AV
                      5CD106FHSQ
                      MB model: X8M-6L
                      Any help is appriciated!
                      • peste
                        • 13436
                        • ROMANIA
                        #172
                        HP ProBook 450 G7
                        6YY26AV
                        5CD106FHSQ
                        MB model: X8M-6L
                        you copied the contents of the bios chip with errors...you did not remove the bios chip from the motherboard...
                        • AppleLover123
                          Lenovo Yoga X380 22LH Supervisor Password removal
                          by AppleLover123
                          Hey guys,
                          have a laptop here that has a supervisor Password (dump in Attachements).
                          Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                          the laptop works but everytime it wants me to type a supervisor password i never set.
                          I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                          Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                          04-17-2025, 03:42 PM
                        • mferna14
                          Password removal on MacBook Pro A2159
                          by mferna14
                          Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                          05-13-2025, 04:16 PM
                        • Badpatch02
                          Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                          by Badpatch02
                          Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                          So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                          I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                          11-30-2024, 05:22 AM
                        • Johnny h
                          Asus M7600R BIOS Password request/removal
                          by Johnny h
                          I'm hoping someone can assist me.
                          I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
                          It still boots into Windows (boots from whatever SSD is installed but not from USB).
                          The model number is M7600R and serial number is N8N0CX03H71131C.
                          I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
                          I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
                          Code:
                          tmNx\'=QJQ
                          04-10-2024, 06:13 AM
                        • coolshrimp
                          T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
                          by coolshrimp
                          Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
                          See Diagram for Wiring.
                          Use MEC-1633#ISP on your RT809h
                          This is same Jtag pinout and method for T490S/X390
                          (But your R/W 10K Resistor Location May In a Different Location)
                          MEC-Chips Store Bios Password In a Secure Un-Editable Area
                          Following steps clear that secure area to re-initialize itself to default (Blank)
                          10-24-2022, 12:18 AM
