T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
  • coolshrimp
    • Nov 2016
    • 54
    Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
    See Diagram for Wiring.
    Use MEC-1633#ISP on your RT809h
    This is same Jtag pinout and method for T490S/X390
    (But your R/W 10K Resistor Location May In a Different Location)
    MEC-Chips Store Bios Password In a Secure Un-Editable Area
    Following steps clear that secure area to re-initialize itself to default (Blank)
    Removing Bios Password Steps:
    -Read MEC Chip
    -Erase chip
    -Unplug power from board for 2 Min
    -Write dump back that we just read.-Password Is now Gone
    Remember to move R/W Resistor Back To Original Position For Normal Operation.
    After clearing bios password you have also wiped the serial and model number to restore them use the ThinkPad Config Information Update Utility.
    Serial/Model Info can usually be found on motherboard stickers and bottom cover.
    To set the Serial Number, Model Number, Etc back onto a Lenovo T14s:
    I Used "ThinkPad Config Information Update Utility v1.11" attached
    -Extract and run "usbfmtpw.exe" this will format your USB and copy the files over.
    (check that the files copied after format. if not manually copy them to the root of the USB).
    -Insert to laptop and boot to USB FDD it is EFI not Legacy (USB you just created).
    -Now go 1, then use 2 to read current keys. record any keys shown, take a photo of them they will be erased if there not already.
    -Now go back to main menu and choose initialize EEPROM, this clears all keys plus UUID and now the overflow error wont happen.
    -Now go 1, then use 1 again to add new info, enter C0 then Enter.
    -Now enter serial and model in long form will start with 1S so (1STTTTMMMMCCSSSSSSS)
    -Enter and Key is stored.
    -If you like can add more or go back and use option 3 for a few more config details. (I set my brand name there)
    -Once all info is set go to assign UUID, and say Yes.
    (once you generate the UUID you cannot edit the serials unless you initialize and do them all over again.
    -Reboot and check bios screen your info should be there no more beeps on boot.
    Product ID: TTTT-MMMMCC
    Serial#: SS-SSSSS
    TTTT = Machine Type
    MMMM = Model Type
    CC = Country Code
    SSSSSSS = Serial Number
    Coolshrimp
  • coolshrimp
    • Nov 2016
    • 54
    Re: T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
    Add to a Sticky Guide?
    • mily.gawel
      • Aug 2018
      • 42
      • Polska
      I tried this on my x390 but it still booted up with a password after all the procedure.
      • coolshrimp
        • Nov 2016
        • 54
        Did the laptop die after erasing the chip? What Mec-16xx chip?
        • mily.gawel
          • Aug 2018
          • 42
          • Polska
          the laptop was dead after cleaning, after uploading the same charge again and moving the resistor to its place, it turned on correctly but still has the password. MEC1663-BA0
          • coolshrimp
            • Nov 2016
            • 54
            Did you try to remove the charger, bios and main battery after erasing chip.
            Let it sit for 5min then reflash and boot.
            Also it's the same chip but maybe this model the password is stored in the bios image. May have to manually edit it out or try the Lenovo bios unlock tool.
            • rumpumpel1
              • Jul 2019
              • 216
              • germany
              I used this procedure exactly as described to remove the BIOS password of a T490s (MEC1663). I think I succeeded, at least my RT809H only showed me success messages. After I soldered the resistor back to the old position, the laptop was dead and would not boot. No fan, no LED. Although the 3,3V and the 5V rail are working.
              I noticed the following irregularities: When connecting the charger, the RT809H program crashed. After restarting the program, it behaved normally.
              After I disconnected the charger for a few minutes and reconnected it, there was no fan and no LED. Still I was able to flash the original dump again, at least I got a success message.
              Does anyone have any ideas?
              • didouche1200
                • Oct 2016
                • 380
                • 82679911441
                • DavidSarmaAJ
                I have nm-c891 when i read mec1663 the file is empty any help
                • ranajee7750
                  • Mar 2022
                  • 11
                  • pakistan
                  HI SIR
                  PLEASE TELL ME
                  LENOVO MEC 1663 BAO
                  Svod4 programmer WORK OR NOT
                  • BootLoader1
                    • Aug 2020
                    • 72
                    • Poland
                    Originally posted by ranajee7750
                    HI SIR
                    PLEASE TELL ME
                    LENOVO MEC 1663 BAO
                    SVOD 3 and SVOD 4, 100% work.
                    • rumpumpel1
                      • Jul 2019
                      • 216
                      • germany
                      I tried a second time, this time with a T14s. Everything went fine, but after moving the resistor back the laptop wouldn't start: no fan, no LED, completely dead. Can anyone confirm that this really works?
                      • rumpumpel1
                        • Jul 2019
                        • 216
                        • germany
                        Question about EC Software for Lenovo
                        When flashing an EC on a Lenovo laptop, the software can be taken from any BIOS update package. For example, extracting the BIOS package for a T14s will result in a file C:\DRIVERS\FLASH\n2yuj14w\20231206.10111452\N2YET37W\$0AN2Y00.FL2 containing the EC image. Not exactly: the EC image is preceded by 16 bytes of other data and is much larger than the 192kB of the actual EC image. My question is, do I need to worry about the data after the 192kB?
                        • volinakis
                          • Jan 2021
                          • 3231
                          • N/A
                          It's working but I did chose MEC1633_256kB on RT809H
                          please support this forum
                          • volinakis
                            • Jan 2021
                            • 3231
                            • N/A
                            Re: Question about EC Software for Lenovo
                            EC for T14s is 256kb.
                            • rumpumpel1
                              • Jul 2019
                              • 216
                              • germany
                              thanks, you made my day!
                              Now it works.
                              But that means, that the original description is just wrong: instead of MEC-1633#ISP it should read MEC1633_256K.
                              • rumpumpel1
                                • Jul 2019
                                • 216
                                • germany
                                Here are some more details in order to enjoy the laptop without password:
                                1. Using the ThinkPad Maintenance Utilities you need to set the brand name. Otherweise you get a beep concert during boot and the error message "Product Name is invalid":
                                - Update Configuration Area
                                - brand name
                                - Write brand name to EEPROM
                                - Special brand name
                                - T14s Gen 1
                                2. Probably you want to set the System board serial number:
                                - Add S/N data to EEPROM
                                - B0 - System board Serial Number
                                - enter 21 chars: Machine-Type-Model and System board serial number
                                • hamodeh
                                  • Dec 2017
                                  • 73
                                  • IRAQ
                                  hello
                                  where i find B0 system board serial number
                                  i cant find it
                                  i do every thing ok i charge the io bios and ok remove the password and enter serial number just i have one problem "Product Name is invalid" how can i solve it ??
                                  • qayyum786
                                    • Aug 2018
                                    • 1959
                                    • INDIA
                                    Originally posted by hamodeh
                                    hello
                                    i cant find it
                                    use this tool and follow the instructions given in side and you are good to go
                                    • jacobk1508
                                      • May 2016
                                      • 69
                                      • Viet Nam
                                      My board NM-B861. I use RT809H programmer, I follow the steps and the result is just empty bios file
                                      • volinakis
                                        • Jan 2021
                                        • 3231
                                        • N/A
                                        you have to power the board before reading EC
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • farouk_1994
                                          T14s NM-C891 MEC1663
                                          by farouk_1994
                                          Hello i need T14s NM-C891 i/o MEC1663 bin file and bios thank you.
                                          04-12-2023, 07:10 PM
                                        • Boardview and Schematic Bot
                                          Lenovo ThinkPad T14s Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T14s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T14s boardview and T14s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-07-2024, 07:20 AM
