hp 450 g7 password
  • alberto232732
    • Oct 2020
    • 7
    • mexico
    #141
    Hello colleagues, could anyone help me to eliminate the hp endpoint security driver problem?
    Serial number 5CD9224Z64​
    • hoaca388
      Badcaps
      • Jan 2022
      • 11714
      #142
      • hiends29
        • Dec 2024
        • 4
        • Việt Nam
        #143
        Hello, can anyone help me remove bios password?
        S/N: JPH104KR3Z​
        • hoaca388
          Badcaps
          • Jan 2022
          • 11714
          #144
          S/N: JPH104KR3Z​
          Reread your chip, your backup not good.
          • hiends29
            • Dec 2024
            • 4
            • Việt Nam
            #145
            help me S / N: JPH104KR3Z
            • hiends29
              • Dec 2024
              • 4
              • Việt Nam
              #146
              Serial number JPH104KR3Z​
              • tuyen nguyen
                • Apr 2025
                • 17
                • Viet Nam
                #147
                try
                • hiends29
                  • Dec 2024
                  • 4
                  • Việt Nam
                  #148
                  Originally posted by tuyen nguyen
                  try
                  nó xóa dc thông báo kia, nhưng mất hết serial + model máy b ạ
                    SMDFlea commented
                    Editing a comment
                    This is an english language forum !
                • tuyen821991
                  • Oct 2024
                  • 44
                  • Viet Nam
                  #149
                  use HP BIOS Configuration Utility (BCU) add DMI
                  lên youtube xem cách thêm dmi bằng HP BIOS Configuration Utility (BCU)
                  seri. JPH104KR3Z
                  sku. 6YY32AV
                  ct board. PJPNC038JEP9J1
                  podut name. HP ProBook 450 G7
                  build ID. 19WWR4CT601#SABJ#DABJ
                  Feature byte. 3X476S6b7B7J7M7Q7W7m7saBapaqauawbUbhcAdUdpdqfPk8.D3
                  • nero0o10
                    • Apr 2018
                    • 4
                    • san mateo
                    #150
                    hi can any one help me to unlock hp probook 450 g7 administrator password
                      • 20818
                      Type the laptop serial number, full name and model, motherboard model, etc.
                      read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                      • nero0o10
                        • Apr 2018
                        • 4
                        • san mateo
                        #152
                        hi can any one help me hp probook 450 g7 administrator pass THANKS
                        S\N: 5CD0236CL6
                          • 20818
                          S\N: 5CD0236CL6
                          Try to unlock it yourself using RCUnlocker
                          BIOS guides, methods, resources and tools
                          https://www.badcaps.net/forum/troubl...rces-and-tools
                          • kudo623
                            • Aug 2022
                            • 55
                            HP 450 G7 Admin PWD please help to unlock. Thank you! We tried RCunlocker on this EC dump which cleared the PW but got endpoint failure. The enclosed EC is the original file with the password. Thank you for your help!
                              • 20818
                              Try the endpoint patcher with the main bios - https://www.badcaps.net/forum/troubl...38#post3654838
                              • kudo623
                                • Aug 2022
                                • 55
                                Thanks SM! I didn't take that path because, well, I thought there must be a reason why the RCunlocked EC dump, although successfully removing the Admin Password, produced the endpoint failure? If you look carefully at these posts here, you will come across the same problem and many people just give up. Why? Because how many times can you remove and resolder a wson/sop8 onto the MB? I found that the Main chip does not have to be touched at all. The locked EC dump bin must be modified with a Hex texted editor. All I did was compared the EC files on this site that worked with my EC file that didn't work and it was just a matter of finding out why? It all came down to knowing where to fill nvram with FF. It took me about a half hour. This site is a great resource if one takes the time to do a little research to find out why things are happening or not happening? Thank you! It works!
                                • AppleLover123
                                  Lenovo Yoga X380 22LH Supervisor Password removal
                                  by AppleLover123
                                  Hey guys,
                                  have a laptop here that has a supervisor Password (dump in Attachements).
                                  Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                  the laptop works but everytime it wants me to type a supervisor password i never set.
                                  I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                  Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                  04-17-2025, 03:42 PM
                                • mferna14
                                  Password removal on MacBook Pro A2159
                                  by mferna14
                                  Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                  05-13-2025, 04:16 PM
                                • Badpatch02
                                  Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                                  by Badpatch02
                                  Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                                  So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                                  I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                                  11-30-2024, 05:22 AM
                                • Johnny h
                                  Asus M7600R BIOS Password request/removal
                                  by Johnny h
                                  I'm hoping someone can assist me.
                                  I have an Asus Vivobook 16x Pro OLED laptop which has a BIOS password, and I can't seem to find it.
                                  It still boots into Windows (boots from whatever SSD is installed but not from USB).
                                  The model number is M7600R and serial number is N8N0CX03H71131C.
                                  I tried AMITSESetup Decryptor but the password I got doesn't make sense (it's got a line break and special characters).
                                  I also tried to use *************** MOD EDIT ,redacted************** and it also gave me the funny password of
                                  Code:
                                  tmNx\'=QJQ
                                  04-10-2024, 06:13 AM
                                • coolshrimp
                                  T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
                                  by coolshrimp
                                  Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
                                  See Diagram for Wiring.
                                  Use MEC-1633#ISP on your RT809h
                                  This is same Jtag pinout and method for T490S/X390
                                  (But your R/W 10K Resistor Location May In a Different Location)
                                  MEC-Chips Store Bios Password In a Secure Un-Editable Area
                                  Following steps clear that secure area to re-initialize itself to default (Blank)
                                  10-24-2022, 12:18 AM
