Dell 7530 LA-F591P bios
Hi, can someone fix my BIOS?
It blinks 3,6...bios error
Dell Precision 7530 LA-F591P
ST: 41JW5S2
Thanks!!Attached FilesComment
I was able to downgrade to 1.1.7 (with recovery - modded for Version 1.28 and 1.26 only) (still with ME from 1.42) - best is 1.10.1 no more tpm error on startup - but TPM remains broken - no standy - no reboot - boots only after 20 seconds without the powersupply - where in the bios is the TPM setting ? in the EC settings - hidden from UEFI?Comment
Dell Precision 7530 Was working fine then accidently got unplugged during a bios update. service tag 2JWDJR2 sn# 5556801854 i could only see 1 chip on here that looked like a bios chip Windbond but when reading is was only 1mb file. I tried several times adjust the chip in the holder. If someone could help it would be much appreciated! mb LA-f591p rev 1Attached FilesLast edited by CraigR; Yesterday, 11:13 AM.Comment
post motherboard model, etc.Dell Precision 7530 Was working fine then accidently got unplugged during a bios update. service tag 2JWDJR2 sn# 5556801854 i could only see 1 chip on here that looked like a bios chip Windbond but when reading is was only 1mb file. I tried several times adjust the chip in the holder. If someone could help it would be much appreciated!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Will do, Here is an edited version so please delete my first post for this. Dell Precision 7530 mb LA-f591p rev 1 Service tag#2JWDJR2 Here is the correct bios dump. alsoAttached FilesLast edited by CraigR; Yesterday, 01:04 PM.Comment
It`s the thunderbolt firmware and it could be useful to other members who accidentally erase that chip, so your post can stay.Comment
You reported your post and said you had found a working bios, well i`m happy for you but you could have posted that here, reporting posts is only to be used to report spam etc.Comment
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
