Working DA0ZHJMB6F0 REV F 2020
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have this 100% tested working bios
  • kamkooltech
    kamkooltech
    • Jun 2019
    • 110
    • nigeria
    Re: Working DA0ZHJMB6F0 REV F 2020
    thank you working
    • techtik
      • Sep 2023
      • 19
      • philippines
      thank you sir
      • Rahim Kachere
        • Jun 2024
        • 8
        • Malawi
        thanks it working 100%
        • bodie
          • Sep 2020
          • 5
          • Philippines
          Thank you, 100% working
          • zPwN!
            ENOVA NE14I310 XU133t rev 1.3 working BIOS
            by zPwN!
            Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
            Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
            System SKU NE14I310
            BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
            Motherboard XU133T rev 1.3
            Serial Number IPNBI3X240SM2A01095
            Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
            RAM 8.00 GB
            NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
            01-03-2025, 01:03 AM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Sparklingx
            CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
            by Sparklingx
            So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
            So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
            now all...
            08-29-2024, 01:53 PM
          • Bloodhoundje
            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
            by Bloodhoundje
            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
            I have desoldered the bios chip (GigaDevice...
            03-16-2024, 03:12 PM
          • titomno2
            Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
            by titomno2
            Hi guys,
            On motherboard ACER AN515-52 type LAF951P.
            I fixed issue with not starting computer (it was the PQ201 component not working properly).
            But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
            Basically some HDD spin but are not detected by the bios.
            Already tried following:
            checked the 4 data lines
            #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
            #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
            07-28-2024, 08:30 AM
