Hi I have this 100% tested working bios
Working DA0ZHJMB6F0 REV F 2020
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
by zPwN!Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
System SKU NE14I310
BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
Motherboard XU133T rev 1.3
Serial Number IPNBI3X240SM2A01095
Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
RAM 8.00 GB
NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...-
Channel: BIOS Requests ONLY!
by SparklingxHi,
So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
now all... -
by titomno2Hi guys,
On motherboard ACER AN515-52 type LAF951P.
I fixed issue with not starting computer (it was the PQ201 component not working properly).
But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
Basically some HDD spin but are not detected by the bios.
Already tried following:
checked the 4 data lines
#2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
#3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...07-28-2024, 08:30 AM - Loading...
