Have somebody bios for ASUS X756UA rev 3.1 ?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3593
    • slovakia
    • 20914
    Re: Have somebody bios for ASUS X756UA rev 3.1 ?
    Can you post your bios backup .
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3593
      • slovakia
      Here u go
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3593
        • slovakia
        Laptop not react to powwr button.
        Cleaned ME with your guide and it lives again
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • lrouw84
          by lrouw84
          Hi there,
          01-28-2023, 01:31 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • chudofermer
          Asus Ally rc71l bios
          by chudofermer
          Hello!
          Received Asus Ally rc71l with the wrong bios.
          Have the original package and all serial numbers.
          Can anyone help me understand what is wrong?
          Condition:
          Received with an original box with all serial numbers
          Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
          Got the flash dump, nothing found on DMI section
          No Windows key, just key ID on the box
          What is done:
          1. Flash the latest bios version with serial numbers...
          03-05-2025, 05:42 AM
