Have somebody bios for ASUS X756UA rev 3.1 ?
Tags: None
Re: Have somebody bios for ASUS X756UA rev 3.1 ?
Can you post your bios backup . -
Here u goAttached FilesComment
Laptop not react to powwr button.
Cleaned ME with your guide and it lives againComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by lrouw84Hi there,
I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by chudofermerHello!
Received Asus Ally rc71l with the wrong bios.
Have the original package and all serial numbers.
Can anyone help me understand what is wrong?
Condition:
Received with an original box with all serial numbers
Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
Got the flash dump, nothing found on DMI section
No Windows key, just key ID on the box
What is done:
1. Flash the latest bios version with serial numbers...-
- Loading...
