Dell 3780 EDI73 LA-G711P bios
  • sonsy
    • Mar 2017
    • 71
    • Serbia
    Bios is corrupted od Dell 3780 motherboard EDI73 LA-G711P rev0.3.
    I tryed to put some bios dump from internet, with them laptop turns on, and with delay gives picture, but there is no service tag and other numbers. Because I bought laptop without bottom cover, i dnt know how to find service tag. Is someone have these problem?
    I will update my original bios, so someone can try to repair them:
  • peste
    • 13924
    • ROMANIA
    Re: Dell 3780 EDI73 LA-G711P bios
    try..
    • Claudiomfa
      • Nov 2015
      • 455
      • Portugal
      try and report
      • sonsy
        • Mar 2017
        • 71
        • Serbia
        Originally posted by Claudiomfa
        try and report
        Thanks, I tryed. Laptop wont turn on at all, no led diode, nothing.
        • sonsy
          • Mar 2017
          • 71
          • Serbia
          I tried to put his original bios with which he turned on and off after a few seconds, and now he won't turn on at all with that bios. This leads me to conclude that I have bad bios reading. That's also a reason why the bios you sent me don't turn on the laptop at all.
          Otherwise, I always read the bios twice, compare them with each other, and if they are the same, that's it. This time, when I tried the second reading, I accidentally entered the erase command, so I was left with only one dump that was not verified, and which turned out to be poorly read.
          My question is: Can someone fix that bios or use data like service tag and other from it, or is there any version that can work on any laptop, such as clear me.
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            try this file
            • sonsy
              • Mar 2017
              • 71
              • Serbia
              try this file
              It will not turn on...
              • peste
                • 13924
                • ROMANIA
                try..
                • sonsy
                  • Mar 2017
                  • 71
                  • Serbia
                  Originally posted by peste
                  try..
                  It works
                  Sorry for writing the result after so much time, I only found time last night to write in the dump you sent me.
                  When it turns on, it seems to me that it automatically turns it off and then on again, which is why there is a slight delay before it turns on the screen.
                  Is that service tag written in that bios dump its original?
                  • frattainfo
                    • Jun 2017
                    • 15
                    • Brazil
                    try..
                    Perfect! Working 100%
                    Which version of CSME System Tool did you use to edit de ME of this bios? I tried all of versions that I found and can´t open this bios!
                    If you can Clean the ME of this bios, I would be very greatful! It´s working but it lasts much time to show video.
                    Thanks!
                    • peste
                      • 13924
                      • ROMANIA
                      Thanks!
                      use the ME Analyzer program here .... here you have everything you need ..
                      https://www.badcaps.net/forum/showthread.php?t=88533
                      • frattainfo
                        • Jun 2017
                        • 15
                        • Brazil
                        Great! Thank you very much!
                        • rogerio.massaro
                          • Feb 2021
                          • Brazil
                          Bios 100% ok
                          • ricaik2005
                            • Feb 2017
                            • 22
                            • Ghana
                            use the me analyzer program here .... Here you have everything you need ..
                            please repost the dump file old looks corrupted.
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              Corrupted? What makes you think so? The file is OK.
                              Become a Badcaps supporter
                              Thanks to all supporters.​
                              • ricaik2005
                                • Feb 2017
                                • 22
                                • Ghana
                                Originally posted by vesko356
                                corrupted? What makes you think so? The file is ok.
                                thanks
                                  • 22279
                                  unzip it and send me if not corrupted. I have tried all possible means.
                                  Update winrar or use 7-zip if you can`t extract the file
                                  • CeeEee4
                                    • 43
                                    • EU
                                    Hello
                                    I have Dell Vostro / Inspiron 3570, it no post, voltages are present on cpu and gpu and they get warm. Just 2 amber led flash.
                                    if someone can fix please.
                                      • 22279
                                      Originally posted by CeeEee4
                                      Hello
                                      Off topic, this thread is for the 3780
                                      • CeeEee4
                                        • 43
                                        • EU
                                        apologies, it is for Inspiron 3780 and Vostro 3580, both model names are in bios dump.
                                        I have Dell Vostro 3580 / Inspiron 3780, it no post, voltages are present on cpu and gpu and they get warm. Just 2 amber led flash.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
