Plss ineed asus bios qcl41 la 8224p
  • renald21
    • Sep 2020
    • 33
    • Philippines
    qcl41 la 8224p
    pls pls.. Tnx
    • 22293
    Re: Plss ineed asus bios qcl41 la 8224p
    For the Asus K54VD ? Post your bios backup
    • PURNAMA
      • May 2020
      • 64
      • jakarta
      i need dump
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        Originally posted by PURNAMA
        i need dump
        post the full name and model of the laptop and the backup copy of the original laptop bios.
        • aboumohamed
          • Dec 2018
          • 259
          • algeria
          try this dump
          for Main Asus K54 K54C K54VD
          • PURNAMA
            • May 2020
            • 64
            • jakarta
            sorry all,because user need to hurry the laptop has been taken
            • psinh99
              • Feb 2015
              • 54
              • viet nam
              Please I need bios Asus K45v,
              mainboard code: QCL41 LA-8224P REV 1.0
              My backup bios
              Thank you advance
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
            • ferah831208
              help with bios decompose for Asus s5506ma
              by ferah831208
              I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
              08-24-2025, 05:35 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
