Plss ineed asus bios qcl41 la 8224p
  • renald21
    • Sep 2020
    • 23
    • Philippines
    qcl41 la 8224p
    pls pls.. Tnx
    • 20374
    Re: Plss ineed asus bios qcl41 la 8224p
    For the Asus K54VD ? Post your bios backup
    • PURNAMA
      • May 2020
      • 64
      • jakarta
      i need dump
      • peste
        • Dec 2016
        • 12274
        • ROMANIA
        Originally posted by PURNAMA
        i need dump
        post the full name and model of the laptop and the backup copy of the original laptop bios.
        • aboumohamed
          • Dec 2018
          • 258
          • algeria
          try this dump
          for Main Asus K54 K54C K54VD
          • PURNAMA
            • May 2020
            • 64
            • jakarta
            sorry all,because user need to hurry the laptop has been taken
            • psinh99
              • Feb 2015
              • 50
              • viet nam
              Please I need bios Asus K45v,
              mainboard code: QCL41 LA-8224P REV 1.0
              My backup bios
              Thank you advance
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
            • DynaxSC
              by DynaxSC
              06-14-2024, 03:49 PM
            • chudofermer
              Asus Ally rc71l bios
              by chudofermer
              Hello!
              Received Asus Ally rc71l with the wrong bios.
              Have the original package and all serial numbers.
              Can anyone help me understand what is wrong?
              Condition:
              Received with an original box with all serial numbers
              Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
              Got the flash dump, nothing found on DMI section
              No Windows key, just key ID on the box
              What is done:
              1. Flash the latest bios version with serial numbers...
              03-05-2025, 05:42 AM
            • maciek1221
              Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
              by maciek1221
              Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
              Config:
              Model: Asus G512LV-HN235T
              Platforma: G532LWS rev. 1.3
              CPU: intel i7-10870H
              GPU: nVidia Geforce RTX2060/...
              03-07-2024, 07:54 AM
