Microsoft Surface Pro 7 NEED BIOS. HELP!
windows log an off plz fix
sn 080654502853
jalama_icl_mb b\dv:2.0bAttached Filesif you find these attachements useful please consider making a small donation to the site
FixedAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Hello could anyone Help me pls ?
Windows Logo shows for 5 sec and goes off
Surface 7 Pro
SN: 059678704853
BIOS Dump attachedAttached Filesif you find these attachements useful please consider making a small donation to the site
i have a Surface 7 Pro shows Win Logo for few sec than off..
the Battery is full 8.4v measured
i tried it connecting Mainboard with Power Supply Standby about 10mAh then when i press Power Button it goes up tp 130mAh and than off
The only strange thing is that when I plug in the charging cable and check with a thermal camera, I can see the charging IC BQ25713 lighting up when I press the power button. Windows Logo goes off but the IC still lights up under the Thermal Cam. I'm not sure if this happens just because the charger is connected, or if it's normal.
maybe is my BIOS broken can anyone check it pls ? i uploaded it
SN: 059678704853
Thanks in advance guysAttached Filesif you find these attachements useful please consider making a small donation to the site
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
TryHello,
SN: 059678704853
hi i found a new BIOS but need to clean ME.. could u please help?
SN: 037778302353
if its work i will let u know.Attached Filesif you find these attachements useful please consider making a small donation to the site
HereAttached Filesif you find these attachements useful please consider making a small donation to the site
THANK U!!!
now device working booting but touch not working.
can u copy the touch section from old bios to the new bios dump ?Attached Filesif you find these attachements useful please consider making a small donation to the site
MS Surface không có màn hình cảm ứng sau khi vệ sinh ME Firmware **FIX**
Tải xuống trình điều khiển và chương trình cơ sở cho Surface
https://support.microsoft.com/en-gb/...pdate-manually
Nếu bạn cần trích xuất chương trình cơ sở từ trình cài đặt MSI
Trình điều khiển cần được trích xuất bằng công cụ dòng lệnh MSIEXEC
Khởi chạy CMD với quyền nâng cao
cd đến thư mục mà bạn đã tải xuống gói trình điều khiển MSI
Nhập msiexec /a SurfacePro6_Win10_16299_1900307_*.msi TARGETDIR=C:\SurfacePro6Drivers /qn (* cần
được thay thế bằng số chính xác có trong tên tệp và bạn có thể sử dụng
thư mục đích của riêng mình)
Thư mục đích sẽ được tạo tự động nếu chưa tồn tại Trình
điều khiển sẽ được trích xuất và lưu tại vị trí C:\SurfacePro6Drivers\SurfaceUpdate\Drivers
------------------------------------------------------------------------------------------------- Hình
ảnh phục hồi Surface https://support.microsoft.com/en-us/...recovery-image
Bộ công cụ chẩn đoán Surface https://support.microsoft.com/en-us/...0-1982eb16f7b5
Chỉnh sửa lần cuối bởi SMDFlea ; 06-10-2023, 04:15 AM .
Hello
the patient is a surface pro 7 that starts with the logo for a few seconds then shuts down
sn:01900204153
could anyone help me please?
ThxAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello everyone 🤗, Can anyone help clean the me on surface pro 7+ 1960, it starts,but shows only logo, consumption 1A, and CPU heating, SN 001140932853Attached Filesif you find these attachements useful please consider making a small donation to the site
Surface Pro 7+ model 1960
039121513653
Shows logo, bootloops after 5-10 seconds
Doesn't boot into OS
Doesn't go into UEFI
All power rails voltages are present, no shorts on main rails.
Tried clearing NVRAM - did not work
Attaching both dumps
Please help with fixing dump or at least tell me what I can try to do myselfAttached Filesif you find these attachements useful please consider making a small donation to the site
my bios sometimes runs fine. but after a while the screen goes dark. is it a bios error?
SN: 003335610753Attached Filesif you find these attachements useful please consider making a small donation to the site
This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11P boardview and Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11P schematic. Our users have donated over 1 million documents...09-07-2024, 04:10 AM
This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 512 GB, i7, 16 GB, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 512 GB, i7, 16 GB, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 512 GB, i7, 16 GB, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over 1 million documents...09-07-2024, 04:10 AM
This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P boardview and Microsoft Surface Laptop Studio, 14.4", 1000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P schematic. Our users have donated over...09-07-2024, 04:10 AM
This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over...09-07-2024, 04:10 AM
This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over 1 million documents...09-07-2024, 04:10 AM
- Loading...
